1/48 Tamiya A6M3 Zero "Hamp" (Completed)
I have this build going on in the Japanese GB IV forum, but since many of you don’t read all of those I though I could also post this one here.
It is a Tamiya 1/48 A6M3 Zero, apparently it’s an old kit as well. Hey, they’re cheap. Anyway I decided to build this one because I want a Zero in my collection and I want one that fits what my mind imagines what they may have looked like, so this one is mostly OOB mainly due to the fact that there just isn’t really anything available for this kit in the AM. Which is disappointing because the quality of the kit is great and the fit is fantastic. It’s an easy build for sure, but the kit lacks major details in some areas that are desperately needed.
This kit doesn’t contain too many bits, but enough to make a decent little Zero. The thing that stands out to me, even though it’s an old mold, is the fit and lack of flash. Outstanding indeed. I began with some painting of the cockpit in cockpit green XF-71. I understand now this is lighter than Mitsubishi painted their cockpits, but it looks fine to me. I then painted the panels and boxes Mr Color C18 Black Green as there appears to be some evidence that suggests they were painted black green rather than flat black. I also painted the engine Alclad Airframe Aluminum while I was at the booth.
I then set about trying to duplicate the aotoke color since I don’t have that color in my paints. I first laid down an Alclad Airframe Aluminum base followed by several coats of Tamiya X-23 clear blue and then two coats of Tamiya X-19 smoke to darken it up some. I like the way it turned out. I was using photos of some interior panels from survivor planes and that color was odd and quite dark but it changed color across the panel. This is the best I could come up with to replicate that look. I painted the inside of the cowling and landing gear bays and doors in this process.
Now the kit cockpit is the most lacking part of this kit. It is devoid of most of the detail and reminds me of an older Revel cockpit. It really needs a resin piece to make it look better, the details just are not there. But I used the kit decals for the instruments and added a few PE pieces I had left over from my Me410 to add some levers on the left console and I scratch a pair of charging handles for the machine guns and added them on as well, they are very hard to see and quite small. I also scratched up a handle on the right of the pilots seat that the kit doesn’t offer. I got this idea from looking at Hasegawa kits which have more detailed pits. I added the loops for the rudder pedals from fine solder wire and then dry brushed the pit using Tamiya Weathering Master kit silver. Short of that the pit is OOB.
The engine in the kit if not too bad for a low detail kit. I did add pushrod tubes painted grey. I sealed the assembly up and gave it a wash with Flory black and then set about attempting to wire it up. Now understand that I had a great photo of a Zero engine that clearly showed the harness in a twisting pattern up to each cylinder. But, since then i have installed a new OS and I can find that photo to save my life. All the photos I find online show a much simpler harness, and frankly one that looks better than my attempt. I just don’t like it, it’s too busy. I’ll do the next one differently. I sealed the whole thing up with Tamiya smoke.
The two halves of the fuselage went together without a hitch, no filler needed and the wings assembled just a tightly and attached to the fuselage with only glue and some mild sanding. Perfect fit. This kit is really impressive in that regard.
I then painted the cowling and underglass area in Mr Color Cowling color C125, which is a black with a hint of blue in it. There are some photos of an unrestored plane that indicated the underglass area was not flat black as originally thought but a black with a hint of blue so they think now the two colors may have actually been the same thing. So that’s how I painted it.
Yesterday I was completing the tedious task of masking off the canopy glass and was nearly done when disaster struck. The rear piece snapped in two like and egg shell. The kit came with both open and closed canopy versions so I cut the rear portion off of the closed version and have it looking quite nice. The only trouble is the piece that broke was narrower and allowed the canopy to be mounted on top of it in an open postion. So, it just won’t sit correctly and looks terrible. I was forced to order and vacu-formed piece and masking kit to solve the problem. If that doesn’t work I will contact Tamiya for a replacement piece. SO the kit is shelved awaiting canopy parts.
Fine work on the Zero there! I snapped a canopy on a Wildcat just like that once.
These old Tamiya Zero kits are still great kits. I’ve built several and wouldn’t hesitate to do another, and like you said they are relatively inexpensive. Nice work so far, I’ll be watching this one.
Brandon,
Nice start on the Zero. Sucks that the canopy broke. Good luck with the Squadron replacement.
Steve
Very nice start! I would suggest that you contact Tamiya Customer Service ASAP for a replacement canopy part. They are exceptionally prompt and responsive in my experience.
Looking great Brandon. I have the same kit in my stash and the figures are a nice touch too I always found the raised fuselage and scribed wing panel lines unusual. Its like the technology changed half way through the design of the kit nd they said…ahh screw it!..lol. There may be an Eduard PE set for that cockpit, but yours looks great as is. I usually add a touch of XF-49 Khaki to my XF-71 to make it more Mitsubishi-like. That Aotake looks great too, I do it the same way but I also add a touch of clear green in there. Carry on my friend…
Joe
I thought about doing the clear green and doing a fade from one to the other across a panel to get that color change affect.
For Aotake I always use X-13 (metallic Blue) mixed with X-25 (clean green). I USUALLY mix 3 parts X13 to 1 part X25. Here are some parts I sprayed today (sorry for the bad picture quality. Best I can do):
Here is a picture I always refer to. You can really see the how Aotake go from very blue (like yours) to very green. You just about cant go wrong, lol.
Mine looks a lot more green in person – my iPhone camera is just not firing on all cylinders.
Brandon, if the vac-form isn’t satisfactory, I have a spare canopy you can have.
Quick update:
Got in my vacuform canopy and the Montex mask kit. Managed to get the canopy cut and trimmed, Future dipped and masked up. It’s installed and when it dries I will fill the gaps and its ready for primer. The canopy is a bit tricky on this kit since the glass basically sits on the fuselage and doesn’t rest in some sort of groove like many kits. This forced me to us the kit windscreen and the vacuform for the other two parts. It fits nice and should look great when it’s done.
I managed to get the Zero in base coat today. As you may be wondering why I painted it red brown as a base. Well, the Japanese apparently, and photos show this, painted the planes a color like this first and then the mysterious grey/green/tan on top of that. So, I will be painting the Zero Mr Color Grey green and I am cuirous to see how this color base coat affects the final color. As we all know the base will have an impact on the final color provided it is not applied overly thick. Since the Zero is new in this build I will not preshade it but rather just Flory wash is for panel lines. This should be interesting.
Okay, now that everyone has had time to settle down after freaking out that I painted this a red brown base I can let you know that the top coat came out with the results I had hoped for. A grey green with just a bit warmer tone and when the light hits it just so, it has a brown tan hue to it. Just what I wanted.
I did pre-shade and I am glad I did as it helped guide me to the correct level of coverage. Otherwise I may have over applied it and lost the base coat affect.
Once I had the coverage with the Mr Color grey green 128 that I wanted I added a few drops of Mr Color 1 to lighten it up a tad and I completed by hitting the the control surfaces with them and just ever so lightly brightened them up and I finished it by added really faint streaking for condensation staining.
The base color was Mr Color 7, brown.
The camera does not show the color as the eye sees it. It is definitly a grey with green in it and when you change the light you can see the brown show through. Over all, I am very pleased with how it turned out, but the color appears washed out in the photo.
Here, I took the shots again on a white back ground without flash. This is much closer to the colors.
After sleeping last night and letting the plane dry for several hours I spent several more looking over photos of Zeros and I just decided that I didn’t like how much pre-shading I had showing so I went ahead applied a few light coats of color focusing on toning down the panel lines. When I got that done I thought I needed to make more a distinction on the control surfaces so I added some IJN grey to my IJA grey green and hit them again. I am extremely pleased with how it looks now. I actually think this may be my best paint job so far. I am starting to get the hang of mixing, thinning and spaying with an airbrush. Hopefully, I will be doing some decals soon.
Your Zero is coming along swimingly.
TY for posting you painting details. My airbrushing is my weekest pont and I am learning much from your posts.
Lol, thanks for the compliments, but honestly I’m just trying new things till I find something that works. If it looks good much of that is due to luck and accident. But thanks again.
This is looking great Brandon…diggin’ the Ame-hiro
Well done with the painting. How did you find the fit of the landing gear doors in the up position? I often have to sand and tinker with this part more often than I’d like to. Some kit manufacturers get it right…some don’t.
Thanks Joe, I appreciate it. I’ll green it up a tad next time.
bvallot, I just dropped them in on this kit, no work at all. (literally none) I only put them there to paint, they will not be used as this one will be sitting. The fit throughout the whole kit has be exceptional. This kit is going together like a dream.
