1/48 Hasegawa Ki-43-I Hayabusa "Oscar" (FINISHED)
After completing my AVG P-40B, I decided I needed it’s nemesis as well. I dug out my 1/48 Hasegawa Ki-43 I “Oscar” to fit the bill. I’ll acknowledge that I’m not a huge fan of the early Oscar, with its two wimpy pea shooter weapons in the cowl and two-bladed prop WWI style, but it was formidable in the right hands and produced many aces. With the exception of Berna decals and PE seatbelts, this one will be built out of the box.
I started with the cockpit. The cockpit on the Ki-43 was very small, so I felt that aftermarket would be a waste here. Furthermore, I didn’t think the stock cockpit was all that bad for what could be seen anyways. I started by thinning out the seat sides to scale then painted everything XF-1 Flat Black as a shadow base. I then mixed up XF-71 Cockpit Green with a tad of XF-49 Khaki to simulate Nakajima Green and sprayed it. My research indicated that most Japanese aircraft only had lap belts (if any), therefore, I added these with some PE I had in the spare box. The boxes were picked out with black silver and then a post shade was added. After a Testor’s Gloss clearcoat, the instrument panel got the kit decal under Micro Sol. I love this option because it looks so much better than i can do. The trick is to get it lined up right over the molded dials. Everything then got a Detailer wash and then a dusting of Testor’s flat coat.
A test fit in the fuselage…it’s good…
See what I mean, once it gets closed up all detail is lost…
This is about two hours of work and I’m already at this stage. This should be a quick build.
Joe
I like it Joe! The lighting looks a little better on the third photo. I think you picked those colors well. I’m not much of an “out-of-the-bottle” kind of guy for painting most things either. =] I’ve got two Zeros that I learned a lot of lessons on. I’m a little anxious myself to do another to see it pop more.
I might have to try that 1st coat of Flat Black trick next time. It seems to be working quite nice here. =]
Great work, very inspiring! If I were to achieve results like that, I wouldn’t believe my hands actually did it! Does that kit still have the raised panel lines? With the instrument decal, are you saying you literally melt the kit decal into the raised instrument faces with Micro-Sol? Also, you get a “most excellent” award from me on the photography!
Great job on the cockpit there Joe!
And that is a really good kit, I built one a few years ago, state of the art quality.
Goodness Joe, your P-40 is still drying!! At first glance I thought that was an after market pit!! Looking great so far!
Joe, that’s a beautiful looking office! Can’t wait to see more!
Steve
Great start! Can’t wait to see more
Awesome! Just awesome. I love the detail.
Thanks for the compliments folks. I figured I would stop in for an update. The honeymoon ended with the cockpit. The airframe has given me nothing but problems. For starters, the port side fuselage piece on my kit was slightly warped, just enough to irritate me. Then the dry-fit of the wings to fuselage revealed the notorious Hasegawa wing root gaps. I ended up gluing the top of the wings to the fuselage to avoid this issue later. Like this…
I added the lower wing then had more problems at the trailing wing edge(s) and where it met the fuselage. Actually the whole trailing edge fit lousy. At the fuselage, I had to fill and sand the seam then rescribe the panel line. I used a sewing needle hucked in my pin vise to restore the rivet detail. No real biggie since this area is usually trouble on Hasegawa kits, but still annoying. Here’s the result after an hour of sanding and filling.
Pehaps my biggest gripe is the wing tip design. Because of the different variants, you have to add them like their sptifire kits. Unfortunately, they’re thicker than the wing (just enough to annoy) and then to complicate things even further, the piece cuts right through the aileron. so you have to fill and sand this area. Its a real pain and alot of that rib detail there was lost. As you can see I still didn’t get it quite right…just a stupid design.
On Hasegawa kits, I only usually primer the seams because their panel lines tend to be on the shallow side. I like to keep as much paint out of them as possible so the wash will stay in the lines later. For a sanity break, I’m probably going to change gears and work on the engine next. I test fitted the engine and cowl which seem to fit good. It took me about 4 hours to get to this point. It’s not perfect but I’m the self proclaimed master of smoke and mirrors…lol.
More to come
Joe
Gee whiz Joe, (or should we call you fermis 2?) you are cranking them out. The CP looks great, it is a shame to bury it and your overcoming the challenges is admirable, looking forward to more.
That’s unfortunate about the wing tips. It seems you’ve got em licked pretty good though! Maybe next time try cutting the ailerons out and setting them up together first. Of course, you make more work for yourself putting them back on. So I guess it all depends on how much aggravation you feel like putting up with. =P
How do you feel about the accuracy of this kit’s panel lines and access doors so far?
I don’t even see the underside seam Joe, looks great to me. Does seem like they’d mold the ailerons separate though, would make it much easier.
Looking good Joe! Those wingtips look like a real PITA.
What nice work…I hope to get to that point…
I was able to get some bench time in last night. As I said earlier, I wanted an Oscar that may have tangled with the AVG. I had Berna Decals in the stash with at least two subjects from the appropriate time frame, being Burma in early 1942. I had success with Berna on my recent zero build, so I decided to try them again on this subject. Of the appropriate planes, I ultimately decided on Isamu Sasaki’s 50th Sentai Hayabusa in early 1942. Did he fight the AVG? I dunno…but his first victory was over Rangoon so the timing is certainly right. Before the war was over, Sasaki would obtain 38 kills to include a few B-29’s. The Berna sheet is really no road map on how Sasaki’s Oscar looked (See sheet and red arrow below) so I alot will be guess work here. The sheet shows the rear end then you have to assume the rest looks like the profile subjects on the sheet. Its confusing. I read somewhere (don’t remember where) that early Oscars were delivered in NMF and then the Green Upper was added in the field. With this reasoning, I ultimately decided on Japanese Army Green (XF-13) over natural metal.
I started with the lower NMF by spraying Alclad Duraluminum. This is my favorite overall shade…not too shiny not too dull. I then taped off different panels and sprayed them Aluminum, Semi-Matte Aluminum, Dark Aluminum, and Airframe Aluminum. I love this technique and really brings a NMF alive. The doped control surfaces were supposed to be a greyish green. I went with XF-76 Grey Green. The wheel wells and flap roofs were taped off and sprayed in a mix of Tamiya Clear Blue and Green to simulate the Aotake Blue commonly sprayed in these areas. Here’s how it turned out after a light post shade.
I flipped it over and preshaded the upper surface for the IJA Green. I used tamiya tape for the fuselage demarcation lines then blue tac for the lower cowl. I added the black anti glare panel on the upper cowl with XF-69 NATO Black. My research revealed that the yellow ID stripes were not used yet in early 1942, so I did not add these.
The glare panel was taped off and I sprayed the upper surface with XF-13 Japanese Army Green cut with a smidge of XF-49 Khaki to brown it up a bit more. I then added a bit of XF-57 Buff and made condensation streaks across the upper wings. A bit more buff was added and I faded the control surfaces. It seems a bit overdone but through experimentation, I’ve learned that the rest of the process (clear cote, decals, wash, dull cote) will tone it down to “just noticeable”. . Here’s where I’m at.
I may still paint in the fuselage band and bisecting lightning bolt in lieu of the decals. I’m undecided. More to come…
Joe
Always love to see your paint finish Joe.
Thanks Reasoned…
Gret paint work as usual! Love the condensation streaking.
Thanks guys. I left off pondering whether to paint the fuselage band and lightning bolts or use the decals. I ultimately decided to have a go at painting them in. Besides, how much tougher could it be than that checkered FW 190 cowl I did a while back. I first taped off the fuselage band and painted it XF-2 Flat White. Here’s a tip when doing this, to eliminate the chance of bleed under. Cut the paint with 91% Isoprophyl Alcohol and use light coats. It dries almost on contact so it never has the chance to bleed under. Anyways, next I used the Berna sheet as reference and used Tamiya tape strips to eyeball how the lightning bolts go. I think I got it close here…
After some more masking, I sprayed the ‘bolts XF-7 Flat Red. I lightened the rudder portion a bit with white. I must say I’m pretty pleased on how it all turned out. Decals?..we don’t need no stinkin’ decals!,
The airframe was then sprayed with Alclad Gloss to await decaling.
I also finished the HA-25 mill. I normally rig ignition wires on all my radial engines but since the Type I had that huge oil cooler up front, I figured I wouldn’t waste my time with this. I built the engine out of the box. I sprayed it Alclad aluminum and the prop box XF-19 Sky Grey. I didn’t have copper, so I dug out my old bottle of Model Master Burnt Iron to represent it. I then gave it a detailer wash then blasted it with a Tamiya Smoke for a used look.
I should get to the decals soon.
Joe
Joe,
Looking good! I like that you painted the lightning bolts and fuselage band - painting always looks much better than big decals like that. The engine looks sweet too!
Steve
