1/48 Eduard Spitfire Mk IXc, S./Ldr. Skalski (Complete)
The subject for this project is Spitfire Mk IXc ZX-6 of the Polish Combat Team, which fought in Northern Africa in the spring of 1943. I’ve been looking forward to doing a desert scheme and this one’s sharp.
Stanislaw Skalski was the leading Polish ace of WWII with 18-11/12 victories during the war, with 4 of them earned while leading his squadron in Northern Africa.
The plan is to build this completely out of the box using Eduard’s Profipack, which is pretty nice so far. I’ll be trying out MRP paints this time and may experiment with a few other new weathering techniques.
Just completed the office.
Shes looking nice so far Hoss. Those Polish groups definitely had a grudge to fill.
I’ll be following this
Hello!
Nice to see you tackle this piece of Polish history!
Good luck with it and have a nice day
Paweł
Nice pit! I have the same kit in stash. I’ll be following.
Thanks Chad.
Making steady progress tempest. Thx
Thanks Paweł. The history is one of my favorite things about this hobby.
Thanks LD. Making progress.
Since the last update, I’ve completed the main build and have applied the main camo colors.
The build was actually quick and there were no real issues. The fit is exceptional and I hardly used any filler at all.
Mr. Surfacer 1200 was used as primer.
I decided to try MRP paints for this build. The Azure blue really pops in person. I faded it a bit also.
Midstone went on next.
I used thin blutack rolls for the dark earth camo demarcation. I like this technique for Spitfires since the camo pattern extends across the wings and fuselage. It’s easier to manage than templates. One thing to point out: The camo profile views of many Eduard kits are inconsistent (e.g., the top view of the camo pattern doesn’t match the side view), and this kit’s no exception. For this build I used the pattern from my Tamiya 1/32 kit.
Once the basic camo pattern was complete, some fading and shading was applied along with some random streaks and patches. A very light coat of the base colors was then applied to tie the effects together.
A bit more weathering and then a gloss coat for decals and wash.
A quick note on the Eduard decals - It turns out that the red color in the roundel and fin flash is sort of a wine red color, not the “dull” or brownish red that MRP has for RAF markings. I found the same thing with the Tamiya decals.
After some research online and checking out some photos, it appears that the spinners for at least some MTO Spitfires were the “dull” red rather than the deeper red on the roundels and fin flash. I’m not an expert at all in this area but thought it was interesting. For what it’s worth, I’m going with the dull red on the spinner after seeing some convincing color photos of desert Spitfires.
There’s also some drama with the maintenance stencils and yellow leading edges for the wings. The Tamiya profile for ZX-6 has no yellow leading edges but does show complete maintenance stencils. The Eduard profile is the exact opposite. Huh?
After some additional poking around online, my conclusion is that this Spitfire had its desert camo applied in the factory so it’s getting stencils. It also appears that the yellow leading edges were not generally applied to the desert camo MTO Spitfires. It’s not clear whether the yellow edges are present from the photos of the actual plane. Overall, the Tamiya profile seems to be more accurate.
Looks great Hoss! How do you like the MRP paints?
Thanks Andy! The MRP paints are good - don’t need thinning, spray well, colors seem accurate, and they dry quickly to a nice semigloss finish. On the flip side, they are expensive and smell pretty bad (lacquers) so you need good ventilation.
The Desert Spitfire Mk IX is now complete. Overall, it’s a very nice kit – quick build, nice fit, good detail and looks sharp.
Since the last update, the X-22/MCLT gloss coat was applied, followed by the fabulous Cartograph decals.
After applying the decals, it appeared to me that that MRP RAF Insignia Red for the spinner would be a jarring contrast (too orange) vs. the deeper red color in the decal roundels. So I oversprayed a thin coat of Mr. Color RLM 23 red, which brought the red-orange of the spinner closer to the red in the decals. I think it looks about right.
A Flory wash was next followed by weathering panel lines with black/brown mix (I tried Tamiya Nato Black and Red Brown per Lawdog’s suggestion – it sprays so much better than my previous Mission Models combo – thanks again). Flat coat was Model Master Flat Clear Lacquer. Some more detail weathering and it was a wrap.
Thanks for following along and enjoy the photos.
A gorgeous model to be proud of. You make it look so easy especially in the post shading…wow.
Thanks Jay Jay - Much appreciated. I’m glad you like the post shading as I spent quite a bit of time on it for this build. This desert scheme lends itself well to fading and shading. Thanks again.
