Howdy, 1/48 prototypical armor fans! [:D]
There have been a few topics posted recently about building older or “rare” kits, and here’s a good example of one.
I was lucky enough to run across Aurora’s 1/48 MBT-70 at a big modelling event in Shizuoka last weekend, and after some haggling (the guy originally wanted about $100 USD for it [:0]) I picked this kit up for a little less than $50 USD. Still pretty pricey, as I’ve seen them going from between $10 to $30 USD, but considering the price of shipping to Japan, I felt it was a good enough deal, so here it sits on my workbench. (Oh, I’m definitely gonna build it!)
Some pix of what I brought home:
The box top.
The box side
The turret, main gun, hull parts, and a track.
The vacuform base.
I’ve specifically paged Major Rob here because I know he’s a big fan of the MBT-70 and of this Aurora kit, but of course if anyone else has any info or opinions about it, please chime in.
I’ve done some research on the Internet about the vehicle and the kit, but I still wanted to talk to our resident experts here at FSM before I get started on the build.
Rob, as I recall, you have four of these kits, yes? And I think you’ve mentioned that there are two styles: the one I have here, in the big square box with the vac base and smooth hull and turret, and the other in the long box with no base and a textured hull and turret.
Which is the older kit? As you can see in the pix above, this kit is marked 1969. If I recall correctly, however, the kits with the vac bases are later issues than the long-boxed kits. I’m not sure.
I’m still debating which way to go with the build. I recall Major Rob saying that the kit is quite accurate as far as shapes and dimensions go (and after looking at references, I agree), so when I picked it up, I was all set to correct any small problems and lack of detail with the full accurization treatment, but after getting the kit home and analyzing what would need to be done, I believe it would be quite an involved project. Not impossible by any means, but even the changes to the suspension alone would require a great deal of hacking and scratching.
Aside from the fact that I’m lazy and don’t really want to do that much scratchbuilding, nostalgia has also tugged at my heartstrings, and I’ve thought about doing it straight OOB, aside from drilling out the 152mm main gun and 20mm auxiliary cannon. But then I consider adding accurate lifting lugs to the turret…more periscopes…and the next thing you know, I’m back at doing a complete accurization!
Major Rob (and all!), can you offer some insight as to how you have approached this kit? I realize that the final decision as to how to build this kit rests solely with me, but hearing some other ideas might help me decide which way to go.
Also, the kit is complete except for three wee parts: one “hub cap” and two “grab rails” (one long-pin, one short-pin). If anyone has a “hanger queen” MBT-70 out there, please email me and let’s work out a “cultural parts exchange!”
Thanks for any and all opinions about this old kit of a fascinating vehicle. [:D]
