OK FSM, my F-100s have been taking up a bulk of my time, but I have been able to get these Apaches started. It’s interesting building these two kits side-by-side because these two kits are at completely different ends of the modeling spectrum.
So, the Monogram kit has the cockpit and lower rotor assemblies molded as one piece. Hasegawa has it molded as two. My Hasegawa kit had a lot of parts loose in the packaging. One thing I found was that part of the assembly had a broken control rod. (It brought back (bad) memories of my Kiowas and Hueys…)
No biggie, though. I piece of styrene rod to the resuce!
Under paint you can’t even tell.
I also got its Monogram counterpart completed. You can also see my start on the cockpit.
I didn’t spend too much time on the rotor area. Once the fuselage halves go together, and the main rotor assembly goes on, not too much will be visible. You can also see that the Monogram cockpit looks a little “rough.” Once all the components go in, it will look better. Trust me.
Speaking of the cockpit components, here are some of Monogram’s.
Again, they don’t look too good now, but I promise things will come together.
Monogram’s cockpit is very simple and basic compared to Hasegawa’s. Hasegawa has many more itty-bitty pieces that build up the details Monogram just molded on. One of the problems with Hasegawa’s cockpit is that part of the pilot’s instrument shroud is molded onto the fuselage halves. When things go together, part of the cockpit tub keeps the shroud halves from joining up cleanly.
To remedy that, I just cut the shroud halves from the fuselage parts. After they were separated, they went together nicely. (I’ll get pictures of that once things have set up.)
I’m still working on the fiddly bits. The parts need a flat coat, and the instrument panels still need some attention. Here’s what things look like right now.
So, that’s where I’m at with these. Hopefully the next update will be the completed tubs, maybe even some fuselage assembly. Until then, feel free to share any comments, questions or criticims. Thanks for lookin’!
Stay tuned!
-O
