1/43rd scale Greenlight diecast
I have a 1/43rd scale Greenlight diecast 2007 Dodge Charger police car and the right front door doesn’t close perfectly flush, but it’s close. The driver’s side is perfect. Does anyone have any suggestions on how to get them to close as flush as they should or what generally causes the issue with a 1/43rd scale Greenlight diecast car? I want to get the right front door flush because I have a decal stripe that goes all the way down the right side of the body. Once that decal is applied, it’ll enhance the gap in the door. Thanks!
I dont personally have any of their 1/43rd but I would imagine it would likely need the actual door jamb shaved down with a dremel. Do you have any pics of the issue?
Tristan,
By my own goof up, I had to take the car apart to repaint the hood (I scratched the hood). So, I decided I’d check it out. I found that the dashboard is too wide by about 0.5mm. As you suggested, it’s time to break out the Dremel!! Thank you for replying.
