I’ve got a project that’s been on the back burners for some time involving a major bashing of the Revell ARIZONA. The big question is, visually speaking, how much difference is there between 1/400 scale verses 1/429? I have played with the numbers, but since most people don’t really know the size of ‘things’, can I put 1/400 scale components on a 1/429 hull and have them ‘look’ okay? THe cost of locating 1/429 scale components is the deciding factor here, as I can buy a 1/400 scale kit much cheaper than buying a few 3D 1/429 scale pieces/parts.
Opinions please. ( I’m figuring that several of you have already figured out where I’m going with this.)
I usually manage to mix scales successfully in that scale from ,Believeit or not 1/350 all the way to 1/500. It all depends on what it is. So be careful and remember “If it looks right, it is”. Many times I use one half the strip on H.O. scale Rooftop Freight Car walkways from Tichy Train Group for rails on the scales you are talking about. Sanding thin and such allows them to bend BUT, they don’t look bad!
i put a L’Arsenal 1/400 quad 40mm gun mount alongside 3D Model Parts 1/429 quad 40mm gun mount with no real differences between the 2. what are you going to kitbash the Arizona into?
I have taken some Arizona models and upgraded them to carriers. This just shows. Great minds do think alike. I always believed that you can create anything if you have a designing streak within you!
