1/35 XM77 "Sledgehammer" New Pics up!
(Re-posted from my original thread mistakenly placed in the “General Modeling Discussion” part of the forum)
i have wanted to do this for a long long time but just now got around to actually getting the resources to actually give my first kitbashing a whirl. in my attempts to occupy my time during study hall at school i drew up a “what if” fortification destroyer/super heavy tank based on the M1A2 Abrams. i showed it to one of my teachers (also a model builder and military buff) and he suggested that i build it in scale… the thought had crossed my mind, but now that somebody else suggested it i had i absolutly HAD to build it lol. I have hinted around to this project for quite some time, but Christmas gave me the opportunity to actually get what i needed to attempt the project. i got the two abrams kits for about $22 each on scalehobbyist.com, they are the trumpeter M1A1/ M1A2 5 in 1 kits (kit no. 01535) and they gave me everything i needed: two hulls (one for chopping the other for building) as well as almost enough road wheels and tracks, and two of the mine plows which wil be mashed into one big one to fit the vehicles wider hull and tracks. i did pick up some Verinden M2 .50 cals though, as the kit supplied ones were a bit soft in detail. I will also be scratching two of the TUSK stye turrets for the top of the main turret. i will be posting this as a WIP. this is my first attempt at a scratch build/kit bash, not sure which one to classify it as. I will post more pics as the build continues…enjoy!
http://i451.photobucket.com/albums/qq239/Sammi1992_2008/Picture941.jpg
the entire kit has a pebbly finish, not just the non-skid surface area.
http://i451.photobucket.com/albums/qq239/Sammi1992_2008/Picture901.jpg
not a great pic, but a basic overview of what i plan to do.
http://i451.photobucket.com/albums/qq239/Sammi1992_2008/Picture839.jpg
as you can see the hull is a bit to short…
http://i451.photobucket.com/albums/qq239/Sammi1992_2008/Picture837-1.jpg
…and a bit too narrow
http://i451.photobucket.com/albums/qq239/Sammi1992_2008/Picture840.jpg
Doner hull is chopped on both sides…
http://i451.photobucket.com/albums/qq239/Sammi1992_2008/Picture842.jpg
…and the bigger hull begins to take shape. because the suspension is offset slightly on each side i had to cut just a piece of each side out and stretch the hull out and full on the massive gap on the bottom with sheet styrene, its there but hard to see in the pic.
http://i451.photobucket.com/albums/qq239/Sammi1992_2008/Picture899.jpg
the bigger hull is then widened by 2 cm…at this point the original hull can fairly easily fit inside the bigger one.
for a bigger hull, bigger tracks are needed, so i took the M1’s standard track inks, cut one part of them off, leaving the alignment spike attached to the track pad i wanted to keep. i then cut off the outermost pad connector from another piece of length, sanded both edges smooth and eve, and glued them together to make a wider track (thank god there were plastic link-and-length tracks in this kit, because the rubber ones were so warped they looked like a black snake slithering around in the box)
http://i451.photobucket.com/albums/qq239/Sammi1992_2008/Picture894.jpg
because the tracks were wider, the drive sprocket and road wheels needed to be wider as well. i made the sprocket wider be attaching the inner piece of the drive sprocket from the second kit to the finished sprocket from kit #1. and since i pan on keeping the alignment spikes for both inside joints on the track, the inner tooth ring on the drive sprocket had to go…Mr. Motor Tool is proving very helpful lol.
http://i451.photobucket.com/albums/qq239/Sammi1992_2008/Picture897.jpg
More to come soon!
Looks like it’s going to be a monster, keep up the good work
Not a real big update, but i got the main work done on the mine plow.
First, i cut the donor mounting frame (top pieces) in an area that i could graft into the second part easily. with the extra width inserted (bottom) i glued together and mounted to the hull.
my original plan was to use something like the picture below…
…but that would barely reach out to the outside of the wider tracks, and would just plow up a massive trench under the tank. so a little chopping, grinding, cussing, dry fitting and gluing later, i wound up with the more satisfactory one below
its wide enough to reach outside the tracks, keeps a good view for the driver, and keeps the bottom of the hull relatively free from excess dirt. the other “ski” is drying as i post this. this is as far as i can go for now, as all the hydraulic hoses and control cables mount to the top of the hull.
my initial though about the quality of this kit was kind of skeptical, but it really gives you a lot of detail for not having any PE, but another thing that really surprised me is that the travel lock for the plow is functional, it can be posed deployed or stowed for rapid movement….
also, just mulling over the bench giving me fingers a break, i had a rather strange idea…(insert evil laugh here lol) and wound up with this…
no worries though, the turret will stay with the tiger hull lol. kinda got me thinkin though…
more to come soon! Upper hull construction starts next!
I always appreciate seeing a project that has a personal “vision”, whether it’s realistic or not. It’s cool to see what comes out of individual minds.
Not saying that your “vision” isn’t realistic either. Though it would probably be prohibitively expensive to build and transport!
thanks doog. yeah i think the transport part would be especially difficult…this would be about 4 feet wider and about 10 feet longer than an abrams and combat weight with the plow of around 95 tons… a bit too big for the C-5 or C-17 lol. im very surprised how smoothly this is going for being my first time kitbashing and scratchbuilding more than a few pieces. surely they arent all this easy.
Looks like an interesting “what-if” project. Don’t jinx things though by thinking everything is going to be smooth sailing…that’s right when the storms hit! [proplr] You’re doing a good job of slicing and dicing with the donor hull and parts, look forward to seeing the end result.
The plow is really coming along great!
You know the more I look at her the more I’d be tempted to widen the turret too and install twin main guns [:P]
i was actually thinking about two main guns, but i was following a build of a tank that was part of the Gundam series that had twin main guns, it looked cool but i thought storing ammo for two main guns would be kind of a tight squeeze lol. i will probably have enough left over parts (im not using any of the kit gun barrels) to make a second turret with the double main guns. other than the periscope ring for the commanders hatch i will have a complete regular Abrams turret to hack up. i plan on using just sheet styrene to enlarge the first turret, not donor parts like on other pieces, so i could modify that one.
also, anybody have any suggestions for official name designation? “Super Abrams” isnt really appropriate i suppose since it is an entirely new tank (albiet made of Abrams parts) i was thinking “M77 Sledgehammer”…im going to drop the “X” because im modeling it as it would be in combat… or should i just keep with the tradition of naming it after Generals? if so, any suggestions for deserving Generals?
Yeah, I think it was the Gundam tank I saw with the twin guns that I thought was really cool.
Lee, Grant, Jackson, Sherman, Patton- most of the cooler generals have already been used. Maybe ‘Juggernant’, ‘Hercules’ or ‘Samson’ would work. Or you could name it the ‘Von Manstein’… [;)]
I think the “Sledgehammer” is a great name. It really packs a rhetorical punch!
Puller…
LOL
I kinda like “Juggernaut” too.
the gundam tank i saw had a camo pattern similar to the red and yellow splinter camo on the Sukhoi SU-37 but in grey and green (i think)
Go all out and use hex tube for the gun barrel. Fashion a round muzzle end, drill some vent holes and you have a rail gun, the next generation of tank weapon for sure.
I am partial to USMC General Officers so names like Henderson, Vandegrift, Gray, Wilson, et al would be my choices. Then you have the legends like Diamond, Puller, Basilone, Boyington etc.
G
Hey, Sledgehammer works for me too.
I was thinking ‘Eisenhower’ might work as a general’s name as well.
M77 Storm (after “Stormin” Norman Schwarzkopf) ?
Again Keeping with the General thing
Ditto, Schwarzkopf.
Or Franks. That would be a great general/ tank name
Kim
“Eisenhower”? “McAuliffe” !!! General Anthony Clement McAuliffe
(July 2, 1898 – August 11, 1975) “NUTS!”
if i dont go with Juggernaut or Sledgehammer i will go with this lol
