1/35 UH-60A Grenada (OP Urgent Fury) Build
I have started on another project I have wanted to do for a while. I am building an early UH-60A Black Hawk from Operation Urgent Fury, the US invasion of Grenada in Oct 1983. This was the first combat action the Black Hawk helicopter had seen, its baptism by fire. These early UH-60As had no wire strike kits, open exhaust, no ESSS wing attachments, no chaff buckets, M60D doorguns, etc.
Here is one in Grenada.
sik_s-70
So far, I have started a test to see if the open exhausts from one of Kitty Hawk’s Naval H-60s would fit onto an Academy fuselage. I want to use the Academy fuselage since it is a cleaner one and earlier than the Kitty Hawk H-60 fuselage. Kitty Hawk’s has a later transmission access panel on the starboard side and reinforcing strips on the tailboom and other areas. Academy’s fuselage is pretty clean with no extra (later) features.
I have the Kitty Hawk Naval HH-60H kit, which has the open exhausts as extra parts since it uses HIRSS exhausts like an Army H-60. I also had bought an extra KH MH-60L C sprue which contains all the other parts for the engine cowlings.
Here it is so far to show that the KH open exhausts and engine cowlings fit on the Academy fuselage. I did have to do some cutting and remove most of the Academy engine cowl parts. It will require a bit of filling and sanding to blend it all together, but a good start.
IMG_20240325_222055385_HDR
IMG_20240325_222055385_HDR1920×1440 383 KB
Hello Gino!
Of course I’ll be watching this. I believe I read somewhere that at this early stage the Blackhawk was having a lot of problems and the soldiers called it “*hawk” and wished they had the Huey back - is that correct?
Good luck with your build and have a nice day
Paweł
Thanks Pawel. Like all new pieces of equipment, it had some issues and Soldiers don’t like change. It proved itself in Grenada though and Soldiers came to love it.
I rememeber the early ones having some sort of problems with the tail controls when first introduced into service in West Germany during the early to mid 80’s, and them getting the nickname “crash hawks” at that time. A fix was eventually figured out.
The ironic thing is, the US military (Navy specifically) STILL has some Hueys in inventory so they aren’t completely gone yet.
The USMC (technically part of the Navy) still uses brand new UH-1Ys and AH-1Zs. So yes, the Huey lives on in US military service.
The US Army retired its last Huey in Dec of 2016, after 42 years of service. It was transferred to the Lousianna State Police where it will continue to serve.
“The last UH-1 Huey, tail number 74-22478, made its final flight as a U. S. Army operated aircraft Dec. 15, 2016.”
I built one of its sister ships, tail # 74-22367, a few years ago (damn its been 17 years!! - I still have it on the shelf too).
https://archive.aeroscale.net/features/1881/
Work continues on the early UH-60A. I am using the Kitty Hawk MH-60L interior on it. A nice thing about the Kitty Hawk H-60 kits, like many other manufacturers, they add new sprues into the box of previous versions to get newer version. Often, this leaves you with extra, unused parts. The KH MH-60S is a navalized version of the Army UH-60. KH gives you all the MH-60L parts and then a few more sprues for the MH-60S-specific parts. You end up with a big box and lots of parts left over. The extra parts include most of the UH-60 interior, including the floor plate, ceiling, and seats. This fixes the weakest part of the Academy kit, the poorly detailed interior parts.
Here it is so far. I made the yaw pedals from left over PE as I couldn’t find all the Academy ones. I also used the Academy collectives and cyclic sticks. I added some button and knob details to the collectives.
IMG_20240329_094042084
IMG_20240329_0940420841920×1650 171 KB
I also used the instrument panel and center console from the Werner’s Wings UH-60A/L backdate set. The crew chief’s consoles/stowage bins on the back of the pilots’ seats from an old Cobra Company UH-60 Update set.
IMG_20240329_094023523
IMG_20240329_0940235231920×1034 104 KB
Close up of the excellent Werner’s Wings analog UH-60A/L instrument panel. It looks really great.
IMG_20240329_094049885
IMG_20240329_0940498851920×1043 113 KB
I am using a pair of gunner’s side panels/A and B pillar interior parts left over from a Warner’s Wings UH-60 MedEvac conversion. I added some left over PE side panel details and vent boxes onto them. I also closed in the KH ceiling with thin styrene to represent the the cloth coverings on the ceiling and rear panel.
IMG_20240329_094141363_HDR
IMG_20240329_094141363_HDR1920×2560 270 KB
IMG_20240329_094211127
IMG_20240329_0942111271920×1428 104 KB
The KH interior also fits into the Academy fuselage almost perfectly. It actually fits better than into the KH fuselage, which is very tight and almost impossible to close up without gaps. You have to sand down the sides of the floor and ceiling to get them to fit cleanly into the KH fuselage.
IMG_20240329_094252171
IMG_20240329_0942521711920×1440 84.9 KB
IMG_20240329_094244939
IMG_20240329_0942449391920×1440 81.9 KB
Work continues. Painting and detailing the interior items is next.
Over the weekend I was able to get the interior painted.
I added drain lines to the transmission drip pan on the ceiling. I also detailed the fabric panels with fasteners and added the H-bar and center bar for the crew chief and troop seats.
IMG_20240401_205129919
IMG_20240401_2051299191920×1440 166 KB
On the floor I added the anti-slip strips in black and first aid kits to the backs of the pilots’ seats. I also added individual instrument decals from a 1/32 jet IP decal sheet to dress up the IP.
IMG_20240401_205141432
IMG_20240401_2051414321920×1440 178 KB
IMG_20240401_205156306_HDR
IMG_20240401_205156306_HDR1920×1440 183 KB
I also fixed the yaw pedals. I realized they were backwards and corrected them by flipping them around so that the center bar is in front of the PE backplate.
IMG_20240401_211440995
IMG_20240401_2114409951920×1440 138 KB
I also added the Academy door interior decals to KH doors.
IMG_20240401_205229768_HDR
IMG_20240401_205229768_HDR1920×1440 235 KB
Here are the gunners side panels / A & B pillar interiors. I added fire extinguishers to them. I also added fabric panels to the rear side walls using sheet styrene.
IMG_20240401_205251736
IMG_20240401_2052517361920×1440 172 KB
IMG_20240401_205320655
IMG_20240401_2053206551920×1440 180 KB
Next up I will assemble the crew chief and troop seats and add them to the interior, along with the pilots, crew chiefs, and a few troopers in the back.
Hello Gino!
Very nice detail on the interior!
How about those fire extinguishers - they used to be red, now I see they are yellow, how come?
Paweł
Hi Pawel. Thanks for the compliments. The yellow-colored fire extinguishers are Class D for combustible metal fires. Some aircraft use them and others use red ones, which are for normal/general fires.
Class D extinguishers: https://fireextinguisherdepot.com/class-d-fire-extinguishers/
Red ABC extinguishers: https://fireextinguisherdepot.com/abc-fire-extinguishers/
It appears both UH-60As w/seats and w/out seats were seen in Grenada. I have seen pics of both ways, like below.
The question is how to do the troops in the back. I am leaning toward no seats and guys hanging out the doors. Opinions??
As posted above w/seats.
1/35 UH-60A Grenada (OP Urgent Fury) Build - Rotary Wing - KitMaker Network
And w/out seats.
File:UH-60A In Flight Over Grenada Wikimedia Commons, 50% OFF
11280×545 109 KB
It’s always fun to ride with your rump on the floorboard and legs hanging out, so my vote is for that method. Usually there is a safety strap on each door opening when that method is used.
Yes, I agree and am going that way. Tracking on the safety straps as well.
Over the last few days, I have made quite a bit of progress. It’s almost ready for paint.
First, I got it all closed up. It wasn’t too hard closing it up. A little bit of trimming on the cockpit floor sides and in the gunners’ windows and it closed up just fine.
Here it is overall. I also used a few spare pieces of PE here and there to add details.
IMG_20240408_213349526_HDR
IMG_20240408_213349526_HDR1920×1440 115 KB
IMG_20240408_213722676
IMG_20240408_2137226761920×1440 112 KB
IMG_20240408_213654235
IMG_20240408_2136542351920×1440 140 KB
On the inside, I added the gunners’ seats and the squad leader seat between them. I had forgotten how much of a PITA the legs are on those seats. After wrestling with them for a while, I finally got them all in place.
IMG_20240408_213424453_HDR
IMG_20240408_213424453_HDR1920×1440 164 KB
IMG_20240408_213500471_HDR
IMG_20240408_213500471_HDR1920×1440 193 KB
I also changed up the cockpit a little bit. I swapped out the collective handles and cyclic grips from a Live Resin set. The cyclic grips are in the pilots’ hands from the same Live Resin UH-60 pilots’ set. They look much better than what I had.
IMG_20240408_213407334_HDR
IMG_20240408_213407334_HDR1920×1440 165 KB
Here is the crew. I started with the Bravo 6 Vietnam Huey pilots and door gunners. I swapped the arms of the pilots for ones from the above-mentioned Live Resin UH-60 pilots set. They have their sleeves down and have the cyclic grips in their hands. They also have the chicken plate armor that was still being worn and molded on seat belts. I added the round seat belt release from the Kitty Hawk PE sheet.
IMG_20240408_214030847
IMG_20240408_2140308471920×1440 151 KB
The gunners are also the Bravo 6 Vietnam Huey ones. The seated one is straight from the set. All I changed on him was shortening his legs a bit to get his butt to sit on the gunner’s seat. The other one I took and added the legs from the standing gunner in the Dragon Vietnam Helo Crew set. I widened his legs, so he straddles the gunner seat on his side. He will be hanging out the gunner’s window and looking back, holding both grips on the M60D MG.
IMG_20240408_213800506
IMG_20240408_2138005061579×1207 275 KB
Next up is painting the crew and installing 3 of them. The standing gunner has to be added after since he will be hanging out the window. Then close up the glass and paint.
I will add the troopers hanging out the side doors and all their gear in the back after paint as well.
I completed the crew. I forgot to take pics before installing them in the helo. Here they are in place. One nice feature of the Bravo 6 crew is they come with PE boom mics. They look pretty good to me.
Pilots
IMG_20240413_103558800_HDR
IMG_20240413_103558800_HDR1920×1440 244 KB
IMG_20240413_103625686_HDR
IMG_20240413_103625686_HDR1780×2201 344 KB
Port side gunner.
IMG_20240413_103743120_HDR
IMG_20240413_103743120_HDR1847×2078 256 KB
The starboard side gunner. He will be added after painting since he will be hanging out the gunner’s window.
IMG_20240413_103811840
IMG_20240413_1038118401906×2414 345 KB
Next up I need to install the canopy glass and tape it all off to prep for painting.
Over the last few days, I was able to get some paint on it. I painted it with Testors Model Master Helo Drab (FS34087) enamel. I bought a few bottles when I heard they were being cancelled. Luckily, I still have a few left.
Here it is overall.
IMG_20240418_203052845
IMG_20240418_2030528451920×1440 75.9 KB
IMG_20240418_203019167
IMG_20240418_2030191671920×1440 71.3 KB
I taped off and painted the black non-slip areas on the roof and the exhausts. I also shot the intakes and the side antennas with black.
IMG_20240418_203031807
IMG_20240418_2030318072436×1118 355 KB
I got it up on its wheels too. For the wheels, I used a resin set by Werner’s Wings. They look great and have sidewall details and the proper groves around them.
IMG_20240418_203111887
IMG_20240418_2031118871920×1440 136 KB
I will be marking it as a bird from B Co, 82d Combat Aviation Bn, 82d ABN Div.
82d UH-60A Grenada
82d UH-60A Grenada894×601 147 KB
I will use most of the common decals on the Academy sheet for stencils and such. I made up and printed out my own decals for the ones that are specific to this helo.
IMG_20240418_203154531
IMG_20240418_2031545311920×1440 44 KB
Lastly, I received one last bit I have been waiting for. I got the Res-Kit M60D doorgun set from Ukraine. They look great and have PE rear grips, PE vented bipods and sights, and all the needed accessories. They should look really nice on it.
IMG_20240418_203126076
IMG_20240418_2031260761920×1440 203 KB
Next up is decals.
After posting above, I realized I was using the wrong 82d patch. I went online and found the right one and printed up a decal for it.
Correct one on the right.
IMG_20240418_214317162
IMG_20240418_2143171622099×1639 365 KB
Actual nose art.
1629×720 49.2 KB
Crew looks great! I love ResKit stuff - great details.
Thanks John. Res-Kit does make great products.
Got some more work done on the UH-60A. Playoff hockey is slowing me down. Go Bolts!!
Anyway, I assembled the rotorhead and blades. I was able to mainly use the Kitty Hawk parts as the naval versions have a totally new/different rotor head and blades. I also had some rotor parts on the extra C sprue I bought. I added the wiring that goes from the center out to each blade too.
IMG_20240427_103959510
IMG_20240427_1039595101920×1440 179 KB
I also got all the decals on it and flattened them out with a coat of dullcoat. Here are the 82d-specific ones I made.
IMG_20240428_192925457
IMG_20240428_1929254571920×1440 166 KB
IMG_20240428_193151761
IMG_20240428_1931517611920×1440 173 KB
Some more overall.
IMG_20240428_192955990
IMG_20240428_1929559901920×1440 163 KB
Port side.
IMG_20240428_193217316
IMG_20240428_1932173161920×1440 132 KB
IMG_20240428_192938820
IMG_20240428_1929388201920×1440 103 KB
Starboard side.
IMG_20240428_193017233
IMG_20240428_1930172331920×1440 137 KB
IMG_20240428_193023488
IMG_20240428_1930234881920×1440 138 KB
I installed the starboard gunner and the Res-Kit M60D doorguns. They came out really nice.
IMG_20240428_193007559_HDR
IMG_20240428_193007559_HDR1920×1440 197 KB
And the port side gunner.
IMG_20240428_193037224_HDR
IMG_20240428_193037224_HDR1920×1440 256 KB
I also started on the GIBs (Guys In Back). They are mostly made up of Dragon ODS-era parts. The torsos w/PASGT armor, heads, and helmets are all from Dragon. The lower halves are mostly from the old Tamiya Armored Troops set since they are seated. I also used one guy from the Dragon USMC Tank Killers set: the seated Dragon gunner (he will be seated against the back wall), and one set of legs in resin from somewhere. The arms are from various kits to make them fit as I want.
IMG_20240428_162417208_HDR
IMG_20240428_162417208_HDR1920×1440 454 KB
Their weapons will be a mix of Dragon (M203 and M60A) and 3D printed M16A1s with 30rd magazines.
IMG_20240428_162444991_HDR
IMG_20240428_162444991_HDR1920×1440 453 KB
Here is their stack of gear that will go down the center of the helo. It has six rucksacks, water jugs, MREs, ammo cans, etc.
IMG_20240428_195454529
IMG_20240428_1954545291920×1440 139 KB
IMG_20240428_195445358
IMG_20240428_1954453581920×1440 175 KB
I’m currently working on all the figures’ camo and finishing up their gear. I need to add some weathering to the helo as well
