I see where 1/35 scale model figures is approximate in scale to #1 scale railroad modeling. But having hard time finding #1 railroad scale model figures… can any one help or enlighten me? Thanks!
Preiser does great 1:35 models which you can use for railway needs
Never seen #1 Railroad scale–Where’d you see this?
Also–A railroading scale equil to 1/35th? That would be convenient–I think we’re limited to what’s available in 1/35th
#1 scale has two differnet sizes here in the US, one is 1/32 and the other is 1/29. Both of these run on G gauge track. Other scales that run on G gauge track are 1/24 and 1/20.3.
Pat.
…Both Dragon and Trumpeter have marketed 1/35th scale locomotives and rail cars but there strictly static. At least I’ve never heard of anyone motorizing on of the kits.
Unfortunately, from measuring the track gauge on Trumpeter #00213, “German Railway Track”, it’s neither an accurate 1/35 standard gauge (1435mm → 41mm), nor is it a match to the 45mm track gauge that both G gauge and 1 Gauge use; it looks to measure out about 42-43mm (there’s a small amount of slop in the fit), which places it somewhat closer to Russian 1520mm (~43.5mm in scale).
Not having started construction on it, I don’t know if there is or how much gauge adjustment you can make on the axles of the Trumpeter #0021 “Schwerer Plattformwagen Type SSyms 80”, but the instruction for Tank Workshop’s resin kit of the same flatcar specifically describe using a piece of track to adjust the position of the wheels on the axles to the correct gauge before gluing them in position.
1 Gauge/G gauge track for scale model railroading appears to be relatively expensive, which is annoying; the Dragon and Trumpeter track is all straight; for the diorama I have planned, being able to have a switch off to a siding that the flatcars were sitting on would add visual interest to that corner of the diorama, but two or three hundred dollars for a casual detail is excessive – and the gauge mismatch means I’d have to use all G gauge track instead of the Trumpeter track.
Now, without having a section to measure, I can’t say what the actual gauge is I can’t say how useful it might be, but I found this item at Amazon (or at hammondtoy.com, which actually services the item on Amazon – search on ‘Newqida Toy Factory’) – G gauge plastic track for battery-driven train sets. At $25 for two switches, 16 curved pieces, and four straight, if the track gauge is compatible with the flatcar kits and can be painted and ballasted to hide its origin as cheap plastic track, it makes a viable alternative to metal track (G gauge and 1 Gauge are sometimes referred to as ‘garden’ scales, because they’re popular choices for garden railways, which is one of the reason it’s more expensive, as it has to stand up to exposure to the weather).
You’re kinda stuck with I-scale figures, which are 1/32 scale… But you can get away mixing and matching 1/32-1/35 in dioramas more often than not… It depends on the equipment around them… Like if have a mixed-bag of 32-35, make sure you use the same scale rifles for ALL of them… While people come in all sizes, weapons don’t, and everyone that’s been as far as the third week of Basic Training knows that the M16A1 is 39 inches long…
