1/35 scale antenna
Looking to create 1/35 scale field artillery antenna set-up. Need measurements of multi sectional antenna with canvas bag, which includes top, antenna inserts, tube poles, support pole to ground tie downs, bottom ground plate, then cable to remote radio set-up. Thanks!
The antenna is an OE-254. I don’t have measurements, but that should give you something to search for and you should be able to find it’s dimensions.
Maybe this is of some help?
