As I need a crew for it, I bought a Vietnam Tanker set from Alpine, number 35162:
I decided to modify them boys a bit. The loader went first. His pose is very nice, but I wanted him to sit there bare-headed, and his CVC helmet is supposed to be nearby. As I had a problem to find an appropriate head in my figure parts box, here is what I did - what I always do in such cases - some heavy surgery! I cut the face out of the helmet and planted in on a Tamiya head:
Next I made up the missing parts using black Milliput:
After it set I sanded the (unintended) rough spots and painted them with brown Gunze paint to check for errors:
I also repositioned the palm of his left hand and took out a little material from inside of the helmet. Tha parts are actually ready for painting:
The track commander comes next:
As I didn’t like his pose, I cut off the legs and replaced them with ones I had in my parts box - from an old Tamiya kit. I also made new cargo pockets out of styrene sheet and I plan to replace the boots with ones coming from a Dragon kit. This one still needs some work before paint.
The next crewmember is supposed to take a rest:
I took his legs from a Dragon “modern” tank crew kit - number 3020. The boots must have nice soles, so I took them from a Legend LF0107 kit - another tankers from Vietnam. The torso, head and arms come from a Preiser kit number 63900 - basically 1:32 naked guys. I still need to redo the trousers a little and reposition the arms.
And that’s it for now - I hope you liked it, thanks for reading and have a nice day
Very cool Pawel! You’re a brave man, I reguarly cut up the cheap plastic figures but not the expensive resin ones. Then again sometimes you have to if you’re to get the pose you want. Thanks for letting us follow along!
Hello Gamera - thanks a lot for your kind words! I didn’t think about it this way - I figure my time is worth way more than those resin goodies, so if I can cut them up to save time, I do that. Plus, I did that many time, so by now I’m pretty confident it will turn out OK. It’s my pleasure to have you onboard! Thanks for your comment and have a nice day
I finally completed the pose of the third CEV crewman. I did this by using wedges made of white styrene plate, glued in and then sanded to shape. They are most visible on the pants, but I also used them on the elbows. I also gave the man nice jungle boots scrounged from the Legend Vietnam Tankers set:
I also added some detail to the pants, like the back pockets made of thin styrene sheet, and also the belt hoops, made of even smaller pieces of styrene. The pants legs were drilled out, to show the pants being worn over the boots and not bloused, like the regulations said.
I think I’ll start to paint them boys soon - please stay tuned. For now thanks for reading and I hope you liked it - have a nice day
Gamera, allan - thanks a lot for your comments, and for your kind words!
Those old Tamiya figs - of course we have better figs now, but they still can be handy, especially when you have to cut up something, and get US post WWII soldiers as a result!
Now I’ve started to paint the figs. First step was to paint all the flesh parts with tan Humbrol 63:
This coat hast to dry really well - several days would be best. After it has dried, I put a wash made of brown Humbrol 113 and some airbrush thinner on the figs:
This doesn’t need to much time to dry - in fact it’s good to start the next step soon, then everything blends nicely - and the next step is a dry brush with a lighter coat, in my case a mixture of flesh Humbrol 61 and white Humbrol 34:
And now it would be again good to let everything dry throughly, so as to have a way to correct eventual errors that might occur at later stages of painting.
But I couldn’t resist and I started experimenting with the eyes of one of the figs - here are the results:
I hope you like it - thanks for reading and have a nice day
Love the poses now that they’re “fleshing” out lol.
I’m going to have to get out of my comfort zone and start bashing my own figures together eventually. Besides minor mods like arms ad heads, of course.
Thank you for the inspiration! Keep it up, my friend!!
templar1099 - absolutely, but only if the patient is styrene/resin!
Gamera&Hunter - thanks a lot for your kind words!
Mike - you’re more than welcome, thank you for your support! Absolutely give it a try, bashing styrene figs isn’t even hard, just be sure to use the right glue (lacquer thinner) and putty (dissolved sprue) - and you just can’t go wrong. Oh, and look at the reference materials frequently - I mean historic photos, but also the people around you. It also helps to recreate the pose you’re aimin’ at personally! Hope it helps, good luck with your figs!
