1:32 with 1:35 scale accessories
How much of a difference is the scale between 1:32 and 1:35? Would it be really noticable if they were mixed?
Am thinking of doing a North Africa diorama with both plane and vehicles.
Thanks for the replies.
Kevin
The actual difference is about 10%. I have mixed 1/32 aircraft, helos, and civilian cars with 1/35 armor and see no issue with it. You can also mix 1/32 and 1/35 figures in the same dio. People come in all shapes and sizes. The key is to keep constantly sized items, such as gear and weapons all the same scale. For instance, do not mix 1/32 and 1/35 rifles together or 1/35 and 1/32 canteens together. You can see some examples of my mixes at my Showcase #1 below.
Thanks,
Kevin
Different scales can also be used to incorporate an illusion of depth. For example, if you use a smaller scale in the background, it might look further away than it really is.
This technique is often very handy in shadowboxes, too. I’ve seen it go so far as to mix 1/48 and 1/72 aircraft in a shadowbox to make it look like aircraft in a hangar.
