So I decided it was time to build a 1:32 scale FW 190. I found this Hasegawa kit on ebay for $35 and snapped it up.
It’s the mount of Lt Hans Dortenmann, Staffel CO of 2./JG 54, which had recently been relocated to France from the Eastern front to defend during the Normandy invasion in June 1944. Interestingly, this plane was only operational for a couple of weeks before Lt. Dortenmann was shot down and had to bale out over Paris. He went on to become one of the leading FW 190D-9 pilots in JG 26 and ended the war with 38 victories.
I plan to build it largely OOB but will add metal gun barrels and will use EagleCals for the decals. I’ll use AK real colors again also.
I just completed the office and engine. I used AK RLM 66 for the cockpit and mission models paints for the engine.
I thought the included pilot figure was actually pretty good so I decided to paint him up and sit him down. I have a long way to go on my painting technique with figures, but you’ve got to start somewhere, and here’s my first attempt. I used some PE parts and masking tape for the harness.
The IP was hand painted this time since the dial detail was decent.
I didn’t spend too much time on the engine since it’s mostly hidden behind the prop fan.
I’ll button up the fuselage and start on the wings next.
Mike and Bish - Thanks for the feedback and encouragement! I’ve been wanting to add pilots and ground crew to my plane displays for a while but am only now starting to learn the basics on how to position and paint them. I spent quite a bit of time positioning the hands on the throttle and control stick as well as angling the head so he’d be engaging the model viewer instead of staring out the windscreen. Since I took the photos I’ve cleaned him up a bit more. Thanks again for the comments.
Thanks for the comments Greg! Although this is my first attempt at modeling a pilot in the cockpit in the last 40+ years, I occasionally did figures with armor models (e.g., Tamiya 1:35) back then.
I’ve been wanting to add figures without them detracting from the plane model overall. I’ve found some references that are extremely helpful and have practiced on two or three ground crew figures before I took a crack at this guy.
I bought this book a couple of weeks ago and have been studying the examples and tips – it has been a huge help!!
Build and main painting work is now complete. Unfortunately I didn’t do a good job aligning the wing roots during assembly so I had some extra filling and sanding work to do.
After priming with Mision Models gray primer, the plane was preshaded with black.
Next, the blue JG 54 RV band and yellow undercowl panels were painted with Mission Models for the blue and AK real colors for the yellow. The main colors then went down – RLM 74, 75, and 76 – all AK real colors. For some panel variation I added some white to the base color and highlighted the panel centers, then blended in again with the base color. The wing camo pattern was masked using the EagleCals profile as a guide. The fuselage camo was sprayed freehand. Mottles were applied in RLM 74 and 75 and then lightly oversprayed with RLM 76 to soften them.
Fine tuned the mottling a bit, added some minor chips/scratches and gave it 2x coats of Tamiya X22 clear gloss thinned 1:1 with Mr Color Leveling Thinner. It’s starting to look like a 190.
I’m calling this one complete. This is my favorite Fw 190A-8 marking scheme and I’m really happy with the outcome.
Lt Dortenmann started in this plane when he was assigned as CO of 2./JG 54 in mid June 1944. His unit had just been transferred from the Russian front to support the defense of France after the Normandy invasion. He shot down a P-51 and a P-47 in this plane a few days before being shot down himself and successfully baling out. He later went on to pilot one of the very first production Fw 190D-9s and ended the war with 38 victories.
This is the first Hasegawa kit I’ve built. Even though it’s a 2004 vintage with a few accuracy issues, it ended up looking pretty good and was straightforward to build.
The only drama in the entire build was self-induced. I accidentally spilled most of the contents of my airbrush fully loaded with black-brown mix all over the port cowling and wing during final weathering. …many things thrown and much noise… I needed to completely repaint a few panels and touch up a few more. The bottom line is that I need more space for 1/32 planes vs. my usual, compact 1/48s. More space is on my XMAS list.
The build was completely out of the box except the machine guns (Master) and decals (EagleCals). I was going to use the Master cannon barrels but I managed to hollow out the ends OK and will save the master barrels for a future build. I used EZ line for the antenna.
I’m really happy with the AK Real Colors paints - really exceptional mid-war Luftwaffe camo colors. I used Flory washes for the panel lines, a black-brown mix (unspilled :)) and some pastels for the exhaust.
The original photos showed heavily spilled fuel stains all over the drop tank so I replicated this by placing several heavily thinned black-brown drops on top of the tank and blowing the fluid down the sides. The photos also showed an almost dead flat finish so I gave it 2x coats of Alclad Flat, which did the trick nicely.
I also adjusted my photo approach – a shorter focal length lens combined with focus stacking – to create a larger depth field for the 1/32 sized plane. I managed to get the entire model in crisp focus for the majority of photos.
Wow! Really impressive build and diorama! Many kudos.
I think the camo and weathering are great! I’m not sure I’d use so much blackening for the engine exhaust streaking but it sure looks good - and you’re probably more accurate than I would have been on those stains.
Hoss, the images of your FW-190 are terrific! For all the years I have been using Photoshop, I had never heard of focus stacking until now. Went to Youtube and watched a demo. Definitely a technique I’ll use in the future when I photograph my finished models. Thanks.
Thanks for the feedback, Mike. Good comments on the exhaust. The amount of exhaust staining shown in the original photos was difficult to tell – a little lighter touch would have been fine I think. Thanks!
