So this last Christmas I was putting together a list of models that friends and relations could pick from if they wanted to add to my stash, and I found myself drawn to pre-WWII stuff. Having visited the USS Olympia in Philly last year, the Encore was a must-have; all the better that the wood decks, PE and other add-ons were included.
There’s a bunch of reviews of the web and they are all generally favorable, but I have to say that it is pretty primitive after the Trumpeter and Dragon stuff I’ve been building since coming back to the hobby after 25 years away. This is more like what remember back in the day. That having been said, it is going together nicely, and I’m enjoying it.
This was my firs experience with turned barrels, and drilling out the 8-pound guns for the upper hull was the first order of business. I started by cutting off the existing gun, and then trying to hold and drill the resulting disk, but then it occurred to me that I could use the molded gun as a handle and cut it off after the new one was in place. I’m slow, but I get it eventually.
The hull halves went together in stages starting from the stern as they were slightly warped and needed to be finessed. I then carved off a number of hull details and added the resin filler and aft torpedo tube, and folded and added the life preserver cages.
The 8-pound guns and their PE were up next. The PE was bent around a paint brush to get the right shape and some fidgeting was needed to get them all horizontal as the fit is pretty loose. They’re not perfect, but I’m happy. I have to keep reminding myself that the more details you add, he less obvious little imperfections become…
I shot the whole thing with some rattle-can Tamiya primer, but overdid it on the starboard aft and had to go at it with thinner and steel wool. From now on I’m using the air brush.
Compared to the Titanic, I’m really chugging along on this one. We’ll see if I can keep it up. I’m finding that I keep switching between projects - I’ve got 6 builds going right now and I work on one until bored and then switch to another. I’ve committed myself to not buy another until one of these are done, so eventually one has to finish.
