The LED strip I bought was the cheaper version (non-waterproof) and does not have the clear silicon dome cover (as drawn on plan). This turned out to be an advanrtage. Now the strip can actually fit between the PVC pipe wall and the reflector. The LED light now can actually penetrate the reflector through its edge, giving off more refracted light. Actually, it turned out to be too bright.
Added a 100 ohm 2 watt resistor to the 12 volt line. This dimmed the light down to a nice hot looking exhaust. Last two photos shows the fan operating.
Top two photos reveal that the LED lighting penetrates through the plastic bulkhead (day and night). I like the look of it. It has that sense of power from the exhaust. The bottom photo show how bright it can get at full brightness (no added resistor).
Tried to figure how to add instrumentaion to the console. Being a scratch build, and newish to modelling, I had no suitable decals. So I experimented with papers, inks, pens and pencils. Photographic paper, for printing, worked well. I do have a colour printer, but the coloured inks are more expensive than the printer (go figure). So I don’t use it anymore.
Peter ! You are into this aren’t you ? Nice job so far . Scratch - Building in plastic is a blast ain’t it ? I am watching . T.B. Newish to Modeling ? Yeah , and I am the Prime Minister !
