I just saw that my local hobby store now has a copy of Revell’s 1/144 scale HMCS Snowberry in stock. The photos of the built up model on the box looked really good. I’m just bummed that I don’t really have $56 to spare right now. [:(]
Aha !
Considering her roots , It would be the best $56.00 you spent , If you are really into ships that is ! T.B.
E-bay offers the HMCS SNOWBERRY kits from $40 to 45.95 range, even one for $39.95.
Best to shop around for a good bargan. Crackers [:)]
I just bought my own copy of ‘The Cruel Sea’ on DVD.
For those who want to build the 1/72 version by Revell, here is an example by Patrick Chung. Really impressive model for those who like the FLOWER Class British corvette.
Happy modeling Crackers [:D]
This has been on my list. Another water scene.
Ah Yes ;
Now the reason I like the Corvettes is apparent here . Lot’s of detail right out of the box . Plus , If you want , in 1/72 it is awesome operating in R.C. and doing real nice , eye catching maneuvers .
This vessel , even with all it’s detail , if built right , will completely weather any real world event , even a ski boat’s wake from twenty feet . ( yes , Like anything , it does have limits ) .
So here is the question for RC boaters.
Does scale float?
It sure doesn’t fly.
I know that a floating model takes very considerable ballast to sit down in the water.
But as far as dynamic motion, I would not think that a scale hull shape would recover from rolling, sail straight or turn anything like the real thing.
How big is this 144th kit?
According to the box figures, right at 17 5/8 inches
I went back to the hobby store today to take another look at the kit. I think if its still there come payday I may have to go ahead and make a purchase (and just scrimp a bit on lunch for a few weeks [:(] ).
After looking at eBay I noticed that with shipping the cheapest versions come out in about $51-53 dollars anyway, with some being much more expensive, so I think I’ll just go ahead and support my local store anyway.
In addition, looking at the detail in the kit (from the photos on the package and other photos on the internet) I’m really tempted (if I buy the kit) to try and build it pretty much straight out of the box too. [:)]
Hi,
I think from the attached link that “time” related stuff scales by a factor of the square root if the scale factor (see page 21 in the attached link http://www.ivt.ntnu.no/imt/courses/tmr7/lecture/Scaling_Laws.pdf )
Regards
Pat
Just over a foot and a half … that’s doable size-wise … but $57 … WOW!
Scale does "float’ unless you get too small in scale. As you go smaller the weight of the plastic parts uses a larger percentage of the total displacement (what the model weighs to float at the waterline.)
The displacement of a model is a cube of the scale-- so a 1/144 scale model will displace 1/(144144144), or 1/2,985,984 of the original. So the real ship displaces 1,036 short tons, which at 2000 pounds per ton, is a little over 2 million pounds. Divide that by the 144 cubed number, and you get a model that will displace about .7 pounds, or 11+ ounces in 1/144 scale.
A 1/72 scale model of the same ship displaces 5.5 pounds. Why the big difference? Because when you double the scale, the volume of the model goes up by a factor of eight. (twice as long, twice as wide, and twice as high)
Plastic models can make great RC conversions. The 1/72 Corvette is 33 inches long, and displaces 5.5 pounds when floating at the scale waterline. The kit parts weigh nowhere near that much, so you have lots of weight allowance to spend on motors, batteries and RC gear. My Matchbox Corvette had a big battery in the bilge, and still needed almost 2.5 pounds in ballast. All that weight so low in the hull made the model incredibly stable.
I’m converted smaller models with no problem. Hull shape is important here. The Lindberg Nantucket is a great model-- even at 1/95 scale, that tubby hull still displaces almost 2 pounds, and it is about 18 inches long. The Lindberg Diesel tug, at 13.5 inches LOA, also makes a great running model, though it will look less toylike and “tippy” if you replace some of the very heavy cabin parts with thinner sheet styrene, to cut down on topside weight. But 14 inch long warship is very difficult- the hull is maybe one fouth the beam of the tug hull.
Hi " G "
Well , no Scale does Not float , but miniature boats do .
As far as ballast , a 1/72 scale Corvette ( H.M.C.S.Snowberry ) Will float at designed war-fit hull depth .
As to the last part .There do have to be changes made to achieve operating parameters close to realistic .On the Snowberry I had to use an oversize rudder and screw ( a tugboat screw .)
The whole thing is to present as realistic appearing performance as possible for the size . Now they do roll with a greater moment of roll and they pitch sharply too .
The trick is to make things appear real .Freeing ports , oversize underwater parts and a good motorcycle battery ( 12 volt ) for both power and ballast . T.B.
Hi Guys, Hey … I am getting the REVELL 1:144 HMCS SNOWBERRY from SQUADRON for $27.59 (using my 40% Author’s discount). Could anyone here knows RCN/RN/RAN/RNZN ships tell me what the SNOWBERRY had for her armament package like in late-1943, 1944, 1945? And what camou scheme she wore in that time-frame, please? Thank you, Tim
Hello there !
You need to contact the Museum up in Canada .I believe that’s where she is at . T.B.
You need John Lambert’s book: Warship Perspectives: The Flower Class Corvette. Another great resource is Bob Pearson’s Flower class website. http://www.cbrnp.com/RNP/Flower/
Snowberry was scrapped in 1947.
Thiis actually is a great hull to model a ship from dozens of countries, Israel as an example.
There were 225, the one remaining is Sackville in Halifax.
Hook us all up w this deal…
