Okay, only a mystery for right now but I’m getting back to an ST project inspired by a ship only seen at that time in a Ships of the Line Calendar.
The nacelles each hold electronics for a ten LED “chaser” circuit to be seen behind the Bussard domes. The ship also has blinking nav-lights and a lit bridge, rear “hangar” beacon and sensor dome. The stand carries the power while the base hides a microswitch, allowing the craft to be removable.
Since the “forum upgrade” are other viewers seeing ‘scrambled script’ from prior posts? I hope that somehow just goes away or that it’s not just my eyes?
Anyhooooo…
With the electronics squared away it’s moving through prep for paint.
Continuing with some refinements I cut the lil ‘indentions’ that flank the nose up front. Oddly, there are more than one version of the picture which made it into the Hard Cover SOTL calendar compilation. One has these indentations while another does not, showing flat faced panels? I chose the one published in the book for some added visual interest.
The Polar Lights Enterprise TOS has several bridge domes to choose from but the Bonaventure has what I’ll call the ‘Reliant or refit’ style extended bridge with dome. Started out by laminating some styrene together to get a big enough block to carve the overall shape from. Also turned down the smooth top bridge dome kit piece to fit within it.
Thanks Griff. While some have told me that they also loved this one at first sight I’m also glad to hear others say it’s now growing on them too!
And moving towards turning on the lights here are the some of the components getting stuffed into the 1/1000 ship. There are 10 LED chasers that go into each nacelle and then the timer for the blinking navlights as well as the color shifting LED up behind the deflector. The LEDs for navlights, hangar bay dome light, bridge and sensor domes are already buried within the model.
Yes, those ten lil LEDs ride a common hub used as the ground and then are controlled by a 4017 decade counter with 555 timer. And they all fit nicely within the inside dome of the nacelle.
Woody,
I have a bit of a “problem” with finalizing this as I would have- since it’s been revised to become the master for casting I will install the lights, snap some pics/video, but then remove all of that. To avoid having to also strip final weathering and decaling- I simply won’t be doing that on this one. Once mold making is done, if this “master” survives the process I’ll finish it off. If not, I’ll be modifying the resin kits to house the electronics and then post one of those. Either way, they’ll be a “break” in progress right after the lights on display are posted.
And thanks gents for following along and the kind words.[;)]
