Zvezda LA-5N 1/48
Zvezda LA-5N, 1/48 Scale
OOB
Paints: Golden & Liquitex Fluid Acrylics
Mediums: Golden - GAC 200, Airbrush Extender, Airbrush Medium: Liquitex – Matte Medium, Flow Aid: Gunze – Acrylic Retarder
Weathering: Promodeller Washes, Tamiya Weathering
KIT:
I suppose I should start by saying that if you want to see a Zvezda LA-5 (razorback version) the way it should be done, check Doog’s recent entry in this forum and in the Eastern Front. As the results no doubt indicate, I can’t say that I shared Doog’s thumbs up on this kit. So, let’s just say this model was a learning experience. I got a lot of practice in sanding, clamping, using CA (which I hate), cutting huge hunks of plastic out of pieces and pushing the envelope on all replacements for putty which I also hate.
This kit was oddly similar to the Eduard FW-190A5 I just completed. Once again, this kit was really designed to be shown with the engine and gun bay open. After these examples, I have concluded if you have an Eastern European model airplane, and it has the option to open major components, open them. Had I done so, this plane would have built very nicely. My mistake was wanting to button it up. This is a very handsome plane (as was the FW) and my 48 scale collection isn’t at “gee, look at the bloody engine won’t you” stage. This kit builds very differently than Tamigawas. The cockpit is constructed into a kind of frame which also holds the entire gun bay and the engine. This means that a slight error at the the early stage of construction can bite you in the face several stages later. (Might add that Zvezda instructions are openly bad. That’s good in a way because you expect to figure things out. Much better than have things look right and be wrong. However, because of the build sequence, you are on your own concerning painting.) I’m not sure how to put this nicely: every major piece was the wrong shape more or less and not one major fit on the entire plane was spot-on, except, ironically, the engine which I didn’t show. The saving grace, if you want to call it that, is that Zvezda has very soft plastic. (This factor apparently also helped Doog’s steadier hand.) Consequently, it was possible to contort pieces (such as the fuselage halves) and get them into shape. That’s the good news. The bad news is that you don’t have a really clean fit. The reason that the cockpit is open, is that it would have required major surgery to close it. It looks ok, but I would have liked the choice. Might add that although the detail was very crisp (not much of it because of the wooden frame found on the LAs) a couple of clear pieces had a haze that Future/Klear couldn’t really cure. Actually, maybe the modeling gnomes were ticked at me. I ordered an Eduard cockpit mask along with the plane. When it was cockpit time, I opened it and found it was for a 72 scale Airfix Nimrod. So I masked the thing myself and did the best job I’ve done so far – on fuzzy clear plastic. Sprue Brothers sent me a replacement – for some reason I don’t see myself using it anytime soon. (For detail fans I should point out that the LA-5FN has major differences from the earlier razorback. I think it’s prettier for one thing.)
Obviously better modelers than myself will have better luck. Indeed, if I did another one I would know what corners you could cut. And I mean that literally. You really only needed the front piece of the engine and about half the frame. If the Queen models and did this kit, I’m pretty sure her reaction would be “We were not amused.” The real lesson I learned is that unless it’s necessary, I’m not buying any more Zvezda airplanes. The LA-5 was a very important plane and good looking to boot - reminds me of some of the Japanese planes. (Small though: about the size of a 109.) So Zvezda was the only game in town. Good for them if they’ve built the BF-109 for the ages - I’ll cheer from the sidelines and buy a Tamiya. (Ironically, I like their tanks.) Yet despite the ulcers and the wasted time, the completed version does look like a LA-5.
Painting and Weathering:
As noted this kit was painted entirely with artist acrylics and mediums. I had a great time but the whole thing can’t be summarized in a few words so I’ll put a post in the Paint forum. Suffice it to say that I got a wonderful base coat (all made from primes and silver) and not a bit of nozzle clog.
This plane and my Eduard FW190 will go into the Ost group build so I wanted this plane to represent a fighter in the middle of the fierce Soviet summer offensive launched after Citadel was defeated. The weather was clear, fighting was non-stop, dirt strips were the norm and Rooskie radials were known to burn oil (so did ours.) I did not want a tidy plane. So I gave it a very flat finish using Future/Klear at a 3:1 ratio with Tamiya base coat. I usually like a flat/satin finish, but this was designed to hold the washes and pigments. The finish was as flat as South Dakota - certainly the flattest finish I’ve ever done. And it certainly gave me the dusty look I wanted. On the underside, however, I did slip a bit. I was fading the color and was trying to blend some pigments with mineral spirits - I used lacquer thinner instead. Luckily, it didn’t demolish the plastic (this was the bulk stuff - not the civilized Tamiya or Gunze version) but it certainly bonded the plastic and pigments. So I had to give it another coat of flat and try to repair with pigments - I had no desire to strip the surface. Pity: I think I created a very nice ATM-7 blue - you can only judge on the wing tips or rear. The antenna is sprue and simplified a bit. At the end, I was genuinely afraid that somehow I was going to wreck this thing totally. It now sits next to the FW.
If you are bored on a Sunday without the NFL you can check out the Ost Group Build and read my thoughts on the air war in the East.
Eric
Pics:
Very nice build, thanks for sharing!
Nicely done Eric.
Regards, Rick
Eric - sorry to hear the -5FN gave you so much trouble! I’ve read that Zvezda made some changes between the La-5FN and the La-5…think they’re mostly concerned with the cockpit detail, but the fuselages are different, too, so maybe there was some tweaking done. I’ve got a -5FN in the stash along with a Karaya Ash-82FN engine (like Vector’s stuff but half the price). Don’t know when I’ll get to it, but I’ll be sure to post how it goes when I do.
In the meantime, I just found out that the annual Austin contest (in October) is going to be doing a “1941” theme this year, so I’m probably going to push the Zvezda 109F-2 up in the build order since it’s the only 1941 bird I’ve got in the stash.
Looks like all the trouble you had was worth it ,the end result is a very nice looking build!
It was a headache no joke - I’m looking forward to building a Tamiya next time - something Japanese. That said, I think Zvezda did get the look right. The LA-5 had very nice lines and was a very important plane - important things. Yet there were some things there that simply baffled me. Maybe you could have done it, but buttoning the plane up with the exhaust installed would have been unthinkable to me. And what possible purpose did some of those rear bulkheads serve other than to complicate fit? There was even some kind of little wheel to be installed back there that couldn’t have been seen unless you cut a hunk out of the side. Some of the Eduard stuff was similar. Maybe Eastern Europeans get a little crazed through their love of blackboard math and strong drink. Methinks the Tamigawa designers are a sober lot. They even give you instructions.
A 109F would certainly fill the bill for 1941, although I’d bet that there were still more Emils in the air in June. And it’s a very nice 109 - hope you find the Zvezda as good as the reviews it’s gotten here among other places. (Both Tamiya and Hasegawa make Fs. I’ve got the Hasegawa Emil - as it stands I’ve never done a 109.) You’re building another really tiny plane. The dimensions of the 109 and LA-5 are almost spot on. I did a walk around with a LA-7 and it didn’t strike me as particularly small, but it was alone. The Smithsonian’s 109 has some company, and it looks like it’s built for hobbits. (I was told that one LW pilot was allowed to sit inside a P-47 right after V-E day and said he thought he could play table-tennis inside the cockpit. Different strokes.) I’m finishing the Ost GB post and am including the Eduard FW190: it looks huge next to the LA5, and in American terms the FW was a small plane. Detroit iron.
I’ve been thinking about 1941 too. The plan for the moment is to pair a Dragon Pzk 38(t) with a Trumpeter KV-2 for the Ost Group Build. (I know there were more KV-1s, but that big turret is too neat to pass up.) I’m going to try to make a Tony Greenland style “too pretty” Pz38 - a first for moi. I’m going to weather the KV with a very heavy hand to restore balance to the universe.
Eric
I’ll be looking forward to the KV-2 - I’ve got that very kit, but in “captured” markings (not that it wouldn’t be hard to make it Soviet again…just paint it green!). Thinking I may tackle it or my Dragon T-34/76 after the Achilles.
Agreed about the 109 being tiny. The 1/32 E-7 I just finished isn’t all that much bigger than my 1/48 P-47! It’s almost certainly the only 1/32 fighter I can fit in my current shelves.
Also agreed about some of Zvezda’s decisions. I didn’t use any bulkheads past what was necessary for the cockpit, didn’t use the exhaust, didn’t paint the engine. Honestly, I thought the engine was a bit lacking. Seriously, with the quality of the surface detail, they couldn’t put friggin’ cooling fins on their engine?
On thing I really liked about the Eduard 109E-7 I just built…it’s very clearly designed to be built opened up, too, but it makes provisions for building it closed up. Wish Zvezda could do an “engine delete” version…but then, the Eduard 109’s cowl fit was less than awesome, so maybe not!
Nicely done. Looks like all your hard work really paid off. [t$t]
