I’ve wanted more Soviet WWII aircraft on my shelves for a while now and I bought this kit and added some resin to the pile. I’m not too keen on Zvezda’s decals so I went with some cool schemes courtesy of AML. But this means I’ll have to back date it to an La-5F. But no fear- AML includes the necessary resin nose intakes and exhaust! Here’s the contents for the build:
The resin includes Vector’s cockpit and some resin wheels, but upon examining the wheels they appear to be totally wrong with a sunken in rim and too small. So i’ll be exchanging them for a set from Aires.
I started with the cockpit. The resin is near perfect with really well done small levers and knobs, which look much better than two dimensional PE.
I added some linkages to the throttle quadrant.
Painted A-14 gray using Gunze colors and given a wash of black/brown oils:
The downside to the resin set is the acetate for the panel has some poor printing, so the gauges don’t come through much at all. Should have gone with eduard here.
Right On Nathan! Excellent work on the office you have done so far. I am more than interested in watching you build this as I picked up that kit for my last birthday. I’ve been gathering some AM goodies for it. How does the fit seem so far? I’m really intrigued as to how well these Zvezda kits are.
Man Nathan. First off I admire any scratch work. On top of that is the fact that you have a good looking interior anyways. Plus the Zvezda approach is good to begin with. Nice looking build so far, Joe
Thanks guys. Joe Rix the fit is pretty good. It takes alittle planning ahead, but it won’t need much putty at all. We’ll wait to see how the multiple cowling parts line up though…
Sorry to dissapoint. I’d rather focus on painting and weathering this thing rather than open it up. But, I do have a resin cockpit and gunbay set for my Gavia La-7 kit, which will be opened up! Hopefully that will see the light of day in the coming months…
Got the cockpit installed in the fuselage and the major assemblies glued up. The wings fit pretty well, but the top and bottom of the gearbays didn’t align very well. I guess they won’t be seen real well though. The fuselage halves fit real good. I just had to make sure that the fuselage width up front matched up with the profile of the windscreen. So this involved some triming of the top of the instrument panel.
Here’s the mismatch gear bays. It left a small step all the way around:
Wing tips need to be puttied here:
Next up is the cowl panels. I hope I won’t need to spend too much time with the putty tube…
I’m finally back to finish off the Lavochkin. I did the Conversion to the F using AML’s resin pieces. It was really tricky to cut off the kits carb scoop on top without destroying the nice detail on the cowlings. The resin scoops didn’t fit all that well and there were some gaps to be filled with epoxy and surfacer. If I could do this conversion over, I’d buy the straight La-5 kit and kitbash the two. Pics of the cowling to follow. I did add a simple piece of card to the back of the spinner, as its missing in the kit. There should be a round plate between the back of the spinner and the fan like this:
Punched it out of card:
I glued it on to the cooling fins. Canopy is masked the whole model is about ready for priming. Stay tuned!
Thanks for hanging in there guys. I see now Eduard has released this kit in a limited edition boxing, with all the pe and resin tires. Decals are nice, but I was hoping for more resin goodies from them, such as an engine or resin guns and gun bay. That kit is still on my list though as I want to build another La-5.
