Hey all, I’m looking for opinions with this build. I’m building Zvezda’s GAZ-MM, maybe someday to put it in a dio. The GAZ-MM was a WWII Russian truck produced with as many wooden parts as possible to save on metals. The goal of this project, more than making a nice looking model, was to experiment with balsa wood, weathering and some irregular paints from Folk Art. I’d like to mimic a dio builder’s aged wood technique from armorama (found here http://www.armorama.com/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=143043&page=2) on the bed of a truck. The bed is not attached yet.
[View:/themes/fsm/utility/
:550:0]
:550:0]
:550:0]
:550:0]
Anyways, when its all done (someday) I’ll have played with the aforementioned wooden bed, and have had firsts in attaching spark plug wires and using pigments. I know that there are still some ugly plastic lugs in the cab floor around the base of the seat (too late to remove) and that much of the plastic is way to thick for scale fenders etc. Doesn’t matter, I don’t have the tools to do the work…anyways…Back on topic, the bed is going to get a coat of Folk Art’s Crackle medium on top of the Folk Art Antiquing Medium which is already applied. Over the Crackle will be the olive green Russian camo, that hopefully will crack up a bit (Crackle is an acrylic paint which somehow apparently will create lead paint like flaking on the top coat, exposing the undercoat). I’ll then scrap the paint out of the damaged wood sections and restain and cover in some heavy washes to bring out the detail. The cab and occasionally the doors were made of canvas; both of which will be replicated as best I can, but in a more ragged form to simulate weathering. I doubt that I can weather the leather seat covers much; but I do remember an FSM issue which demonstrates a technique on how to do it to a derelict car. What else…If I ever get it into a dio, it will be in a ditch half buried, but right-side-up. My final idea is to try replicate a dent; if you’ve seen any old cars with a splintered spiderweb of paint around a dent, then you’ll know what I’m after. I want to do it by masking out a spiderweb pattern on the green topcoat then spraying in a little dark brown or rust color. I’m not sure if it will scale out well, but might as well try for the sake of the order.
Anyways, I apologize for the book which I just wrote, and poor quality pictures, but its the best I can do with my cellphone. I’m looking for any opinions or tips that you all might have.
Thanks!
