Zimmerite
I want to attempt a go at Zimmerite on a TIGER I.
How thick should the application be in mm,1 or less.
If i were to use the putty or milliput method do you have to really force it on the model for adhesion.
If i were to say, roll out a piece and then lightly press onto model this would not stick.
Real Zimmerit was applied in two layers. The first layer was 5mm thick and the second layer was 3mm thick. Depending on which method was used to score, tool, or stamp the pattern into the second layer, this would leave a thickness of only 8-10 to maybe as much as 12 mm thick. In 1/35th scale, this would be only .23 -.29mm, to possibly .35mm thick.
Most modelers tend to exceed scale thickness, IMHO, myself included. [:-^]
Here is a link with some history and application tips;
http://www.track-link.net/articles/15
That seems thin in real life. I believe your numbers though. Do you have any good shots of zimmerit being applied by the methods described?
Here is the article I lifted the numbers from. It is consistent with that which I have read from other authors and from what I have seen on the actual vehicles;
Zimmerit Coating Jagpz IV with Zimmerit coating
To defend against the attachment of magnetic hollow charges (allied counterparts of the Hafthohlladungen) the germans developed the “Zimmerit” coating for their tanks (more info on Zimmerit). Zimmerit consisted of about 40% Barium Sulphate, 15% of ochre/sand pigment (=color), 10% Zinc Sulphide and 10% glue mixed with sawdust; the remaining 25% were Mowilith, a polyvinyl-acetate. The putty was applied onto the surface of a tank’s armor in a first layer that was about 5mm thick and a second layer 24h later which was 3mm thick. The second coat was shaped inot large grooves giving the Zimmerit it’s distinctive look (see pic. at right: Jagpanzer IV with Zimmerit application). The whole applied putty then was hardened using blowtorches.
Zimmerit on Panther glacisThe Zimmerit had no armor value whatsoever and therefore didn’t really affect the mechanism of the shaped charges themselves, it was simply meant as a thick layer of nonmagnetic paste so that the magnets of attached hollow charges wouldn’t hold. The rough surface produced by the grooves was also supposed to hamper the attachment of non-magnetic glue-based sticky mines. Zimmerit was first introduced in 1943 on PzKpfw III tanks. Later all German battle tanks received this treatment.
The picture at left shows the glacis of a PzKpfw V Panther (the bow machine gun is missing).
Because the feared use of magnetically attached shaped charges by the allies did not take place to a sufficient scale to justify the tedious procedure of attaching zimmerit - esp. the expected use of such weapons by the Russian army never realized to a considerable degree -, the whole idea was abandoned again in late fall 1944 (for the Pz V Panther coating was dropped in September 1944) and Zimmerit was from then on rarely added to new vehicles (to read more about Zimmerit click here and here).
As for photos of Zimmerit being applied, forget about not having photos of field applications, try finding a factory shot. I have one, maybe two. I’ll see if I can find them.
This is one of only two photos I have seen where the vehicles are in the process of having Zimmerit applied. One can debate whether or not the men are actually working on the Zimmerit at this moment, but you can see the the vehicles themselves are at different stages of the application process. Note that the vehicle in the foreground does not have Zimmerit on the bow plate and the second vehicle does and it also has the spare tracks installed over it. Also the fact that the one worker is wearing an apron implies that he is working with something messy that he doesn’t want to get on his clothes. The guy standing on the second vehicle appears to be working on the Zimmerit itself…or maybe not, who can tell?
Having seen Zimmerit first hand, the coating is surprisingly thin. I’ll see if I have some close-ups from Koblenz that I can scan in and post.
Not the best photo in the world…But here is a shot of the driver’s hatch opening on Koblenz’s Sturmgeschutz III G;
You can see that the thickness of the waffle-pattern Zimmerit is just a fraction of the thickness of the 30mm hull roof plate. (not including the darker-looking red primered frame piece below the hull plate.)
Thanks for finidng some photos. It would be cool to see a video of how it was done, but I guess we can envision it.
If you decide to use either putty or miliput, you may want to rough up the surface which you want to apply. This add better grip to the putty/miliput.
This process is rather time consuming and delicate (not for the faint heart). The other option will be go to the resin zim. Atak or Cavalier makes them.
Ben
