Hi Everyone,
I am sure the Zimmert topic has been discussed at nauseum, but I need to make a decision on how to apply Zimmert to a Late Tamiya Tiger. I know of the three proven methods. Putty, hot knife or pay the man for the pre made glue on panels. I am leaning towards the putty method. My question is has anyone had good results with this method? IF so is there a very descriptive article that will help me?
I should add that I have used the putty method. The first time I did it, the results weren’t the best. It became easier the second time. Practice on a scrap model if you can
I just ordered that Tamiya Zimmerit tools. I am going to use Aves putty to zimmerit Tiger-I as well. Hope this turns out alright. This same topic has been discussed so many times and so many solutions been posted. I haven’t done any myself, but I’m leaning more towards to doing it with Putty.
I used the Tamiya tools with Squadron Green Putty on a Brumbar, Tiger II and Stg IV I built several years back. All turned out as desired. I would definitely concur with practice first on scrap or on an old kit before you go for it on your project. Now if I could find some stamp patterns in 35th scale for the Stg III waffle style…
Thanks everyone, anyone know of a PE set for the Tiger that has the front and rear mudguards as well as side skirts? I thought Aber made them but do not see now.
Eduard makes several sets that are kit specific. Verlinden has detail set including those items. Lion Roar also makes some kit specific Tiger I sets. Squadron online and Great Modles webstore have images of the items posted.
I think it should be around 5 mm. I’ve done the zimmerit on my Tiger with the paint stirrer from Tamiya which is exactly 5 mm wide. I think it’s close enough. I’ll post some pictures of my completed Tiger very soon. I made it with play-doh and it turned out ok, a little bit thick but that’s not a problem for me and the ones that will look at my model. Next time I do it, I’ll buy that zimmerit tool and use polyester putty.
I like the putty method myself. THe technique Jason posted is great if you practice at it. Personally I didn’t like it. It was much easier to apply putty as an even coat to the model, then use tamiya tools thereafter to texture.
