There was a thread not to long ago by T-rex making a zim wheel with a paint jar lid. The cap from a water bottle has narrower spacing. After cutting it from the bottle….keep it on the bottle for much easier cutting…roughs the surface with a large rough file. Makes it less perfect. One is mounting on a piece of balsa… I am thinking it will make longer pass easier. Maybe next one I will fill with Milliput and make a wheel with a handle. The bottom pic compares it to Cavalier zim. This is a 1st attempt so I have to work on the rolling technique but…. What do you think?
And save a little piece to flatten out for getting into corners, etc–you could even have a couple of “specialty pieces” to get into hard-to-reach spots!
This should go into FSM as a “Reader’s Tip”! Great observation!!!
You may have just removed my trepidations about tackling a project with zimmerit! Thanks Marc…being new here, I missed the earlier discussion…this looks far less time consuming than I envisioned homemade Zim.
The idea of filling the center and adding a handle sounds like the way to go…perhaps with an additional wheel on the other end to keep it parallel with the work surface…then you could just roll it along without worrying about alignment and getting one side deeper than the other…?..
Thanks for showing this…I’m off to cut up a bottle and experiment myself…[:)]
wing_nut: Perfect timing! I just started a thread about zim’, poking around for some info. The look you get from this technique is more what I’m wanting. Is that clay you’re rolling? I assume it’s a water base clay, but I might suggest to those following along to use an oil base clay because it never hardens. With it, once applied, it would be more forgiving and could be tweaked a bit if needed. It adheres well to plastic and wouldn’t chip off during subsequent handling/ weathering of the model. Once in place though, I’m confident a heavy coat or two of future would stiffen it/ lock it down and ready it for primer or base coat. Oil base clays come in small portions too, easy for storing and using later…again they NEVER harden so you wouldn’t have to face buying a big blob of clay and have to store it and worry that it will dry-up.
Steve, with all due respect buddy, I would have to say that that is some of the “iffy-est” advice I’ve heard offered by you–that would probably garauntee a disaster.
You don’t want to spend hours zimmeritiing a model and with a non-hardening clay and then hope beyond hope that a coat of Future is going to somehow magically harden it. I mean, what are you basing that assumption on? There is absolutely no chemical equation or basis for being confident of that that I am aware of.
At best you’d wind up with a model that you could never handle or bump; at worst, you have ruined an expensive model completely (ever try to get that junk OFF of something?!) Not only that, but you have no idea how the compatibility issues with painting, weathering, etc, would develope over time.
Use two-part epoxy putty like Millliputt or the like. It has certainly a long enough setting time to do whatever you would want to do with it. Or any other purpose-made modelling clay/paste designed for this type of stuff. Trying to save a few measly bucks by trying to cut corners on suc a cheap item could wind up costing you the whole $50-60 or more onvested in the kit.
doog: I’d be willing to “take a test drive” and/or be the “Guinea Pig” on this one because I know how the clay behaves and I see some potential advantages. I would think that handling and bumps would be harder on a brittle medium that a pliable one, putting our builds MORE at risk. The clay is not as soft as you might think, it just never fully sets…besides when we handle our models we don’t grab the zim’ed areas anyway.
You brought up some things I didn’t think of though, like the chemical reaction over time. I think I’ll give it a whirl and see what happens[;)].
While we’re on the zim’ topic, would you surf over to my thread on zim’ application, maybe you can help me, thanks doog!
Steve, I can only say that if yo do this, please do it on a scrap piece of plastic, and then only if you must!
Have you ever used Milliput? It hardens like steel. There are absolutely NO issues whatsoever with its durability at all. I mean, if you run over the model with your car, ok; it’ll crack, but by then you’ve got bigger problems anyway…[;)]
Steve that is in fact Milliput. Knead it together and roll it really thin… that’s about 1/16"… with powder to keep is from sticking. Like using flour for pie crust. Rios sent me a toot showing this and it looks great. It would normally be rolled out then the powder is wiped off and the back wetted a tiny bit making it sticky. Put the “sheet” on the part of the hull or whatever and trim the excess. Then do the zim wheel. Cures rock hard.
Well then…now you’ve gone and done it! [:O] You’ve revealed one of rios’ BIG SECRETS! [alien][alien][alien][alien][alien][alien]…[:-^]
My advice would be to immediately pack your belongings!, sell your house!, hide your stash! and go underground! Release the dog!, shave your head!, and send off the wife and kids!!! It’s been nice knowing you and seeing your work, but man, you’re finished now!
(Voice of Mel Blanc from old Looney Tunes cartoons “Oh the huMANITY of it!” followed by the sound of hysterical wailing and gnashing of teeth!..[(-D])
I am curious as to how the roller thing will turn out. I 've tried zim with the epoxy putty before, and had very poor results. Most likely I didn’t let it cure enough before applying. I currently use Bondo lacquer spot putty, lacquer thinner to keep it workable, and a screwdriver as a trowel. Very time consuming process, also danger of ruining nearby detail. I like the rolled out sheet approach, sounds like it would be easy. Still looking for an easier approach than the one I currently use.
Err… did somethig happen before I joined the dark side?[%-)]
WAIT… Don’t answer that. I’ll assume something did and I don’t want to rehash or bring up and bad subject. I am pretty easy going… don’t crap on me… and I won’t crap on (whoever)
doog, you crack me up man!![(-D] LOL!! Shhhhhh…don’t tell anyone I laughed about you-know-who…
BTW, didn’t someone in this forum recently build a…StuG(?) with green Squadron putty zim using the ridged cap from the Squadron tube?? Somehow I think it would be easier to use the cap because it appeared to already be the right width, didn’t need any extra support and seemed like it would be easier to attach to a handle ala AFV Club’s zim roller device.
Gald to see someone flowed my idea. althought it would be better using the real zimm wheel from a LHS, a bottle cap can be just as good. In fact anything round and has “teeth” will do.
