You can tell a modellers car by:
There are a couple of parts in the garage that he couldn’t locate on the instructions.
HEY,
The flames that he put on it are starting to yellow and peel.
There are molding circles on the floorboard.
If it gets too hot outside the car starts to melt.
Randy
You can’t start the engine, 'cause it’s all glued together
or
You can’t open the trunk because it’s glued shut.
or
You can’t fix a flat because this particular Revellogram only came with four tires.
or
For some strange reason, the seats are awfully hard.
or
It’s impossible to tell how fast you’re going, because the speedometer decal keeps peeling off.
or
You have to climb in through the windows 'cause the doors won’t open.
or
When taking the car to AAMCO for transmission repair, the mechanic informs you that the transmission is mounted upside down, and the driveshaft is warped and installed backwards.
Gip Winecoff
or
or
or
or
or
or
Gip Winecoff
There are heat gun burn marks where he tried to straighten the wrinkled fender and his wife’s Benz is covered in Zimmermit
Sorry for the double post. Having major server problems with NETZERO. Haven’t had a decent connection for over a month now.
Gip Winecoff
The photo-etched brass dashboard and the stretched sprue antenna!
The lack of room from buying all those great kits on sale at the local
hobby shop or model show. The only problem is finding room for the kit you
really needed for your next project.
fuzzy
The hood is a diffrent shade than the rest of the car because he ran out of paint and the new stuff was from a diffrent batch than the old.
Lee
One of the wing mirrors broke off when his Mum was dusting it!
Has “NO STEP” stenciled on the hood and roof.
Installed “turkey feathers” on his dual tail pipes and anti-collision lights on both sides
The car is a ‘curbside’ because it has no engine. (I have a couple like that)
The windshield wipers are molded with the windshield and painted only to look real?
In the attic at home he has three unopened boxes containing 1962 Lotus 7’s. And there’s a couple of part built Westfields in the garage that he’s going to get around to sometime, once he decides on a colour scheme!
Pete
has masking on it where he forgot to take it off, never runs out of gas due to fuel gauge problems. cat finally decides to take it for a “spin” off the dresser
I’m dissapointed Guy’s, you all missed this one;
Theres a coat of Future on the windows!
Pete
Your version doesn’t go as fast, because its the standard injection molded version. Your friend has the speedier vacuum formed version, but has a harder time finding parts.
I’m without a car just at the moment, but here goes anyway:
side reflectors and rear window brake light replaced with aircraft “slime light” formation strips.
distrubutor cap is chromed (cool feature if useless on a distributor cap) :slight_smile:
windows tinted with Tamiya’s “clear smoke” paint
chipped chrome is patched with Bare Metal foil
occaisionally a bit of mold flash can be seen on the bottom edge of the body shell
Who’s next?
There are road kill markers under the drivers side window – I got nothing!
Hey all,
He/she has a sign thats on the car window which reads :
CAUTION…!! MODEL ON BOARD
Flaps up, Mike
