Yet another 1/48 Tamiya F4F-4 (completed)
That last pic really shows the work you put into the engine. That is impressive!!
Great looking Wildcat! I look forward to seeing it finished.
This is a really nice build Johnny. I really enjoyed working on this kit. In fact, I have a JPS -3 conversion that is for the Tamiya kit that I hope to get around to one day. Fatherhood has been the priority as of late. Your scratchbuilding is fun to watch as well. Very clever stuff with the cowl flaps. I especially like to see extra attention to the control surfaces like the elevators and rudder (they never seem to get any love do they).
Looking forward to seeing the rest. =]
Thanks all. Very kind.
Two steps forward…
One step back…
I was hoping to get this wrapped up before Christmas. (I was hoping to get this wrapped up before Thanksgiving…)
I’m on the scenic route, I guess. Maybe before New Years.
Happy holidays!
-J
New Year’s update
Wherein we learn an Important Lesson about the order of events and the properties of lacquer thinner.
I wasn’t happy with the paint job of the leading edges of the wings (the line between the top and bottom was too sharply demarcated and not in quite the right place) so I decided to fix. I carefully masked the rest of the model, being mindful of not letting the tape touch the decals, and resprayed. Naturally, I wasn’t quite careful enough, because a bit of masking tape snagged the corner of one decal, and the other one took a hit from overspray. Ugh.
Lesson 1: Be sure you are happy with the paint job before applying decals
I figured, “no problem, I’ll just scrape off and throw down spares.”
After much careful scraping with soapy water, micro-set, and a lot of swearing, I decided to bring out bigger guns. First windex, then mineral spirits and finally lacquer thinner. “Lacquer thinner”, I reasoned with myself, “is the serious stuff. It’ll take off the paint, but whatever, I’ll just repaint the wings and then we’re off to the races.”
The more experienced among us are probably chuckling to themselves about now, seeing where this is headed.
Lacquer thinner does a really good job of taking off decals. Yay. And paint. Okay. And it melts plastic.
Bummer.
Lesson 2: do not use lacquer thinner on plastic
Mrs. 1000 came home from the gym and immediately noticed that the house reeked of chemicals, that I was not paying attention to the kids, and that I seemed a bit glum.
All those lovely details on the port wing are mush. I looked at rescribing and trying to resurrect the rivet detail, but even after 24 hours the plastic is mushy. Even if I could repair the damage, the solvent will keep eating at it for who knows how long.
After much consideration, I decided to salvage the parts worth salvaging and extractable (engine, landing gear, horizontal stablizers and rudder) and start over with the air frame. A new kit is en route and I’ll pick up once I’ve made some progress.
I will finish this model.
In the meantime, I spent some time looking over our entrepid hero, Lt (now Major!) Stub’s ride from summer '44–the legendary F4U-1a, from his tour in VMF-115–and spent most of the afternoon scratch building a new landing gear lever box to replace the underdetailed one that comes in the Tamiya 1/48 kit. Will post about that seperately.
For now, I leave you with an ad from the March 1942 issue of Aero magazine courtesy of Mrs 1000, who isn’t quite sure what to make of this new incarnation of my rolling midlife crisis, but has noticed that I’ve spent quite a lot of time and energy on a little Wildcat.
Happy new year everyone!
-J
Hello Johnny!
Sorry to hear about your trouble! Good thing you’re holding on. Please check that wing one more time - lacquer thinner evaporates, and sometimes it takes a little time, but after two or three days the plastic is hard again, so you could try sanding and re-scribing those panels. It would be a real pity to waste all that god work you did so far. Can you post some pics of the damage? Maybe I could give you a few tips for saving it? Anyhow - good luck with your build and I hope you have a nice Wildcat completed soon! Have a nice day
Paweł
Hello Johnny, I think you are doing a great job for not doing plastic modelling for so long. I am also getting back into the hobby after about 30 some years I and am looking at doing the Tamiya F4F-4 kit but I want to do Foss’s Black 53.Do you know where I can the 53 numbers? George
Thanks Pawel
Gnarly…
If you have ideas about how to fix, I’m all ears. I’m sure it’s possible, but it seems like it would be a project, especially with the goal of getting it really clean.
Thanks!
-J
Johnny, some of the models we see on those forums look worse than that completed, so don’t lose the spirit! The big question is: did it already cure? Give it a day or two just to be sure. What I would do next would be to take a flexible steel ruler or a piece of copper sheet metal to serve as an edge and rescribe the panel lines, make them a little on the heavy side. The Olfa PC-S plastic knife could be perfect for this job. A nice awl could help you to deepen the rivets a little bit. After that, wet-sand the surface to remove the “bumps”, and any dents that are left could be filled with Mr. Surfacer 500. Then just run the awl lightly along the panel lines to remove the sanding dust and that should do it. I’d recommend trying to keep the working area outside of the wing fold, same with painting. This way even if the shade of the paint differs a little, it still wouldn’t look totally unrealistic.
To give you a little inspiration, let me post a picture of a Beaufighter here. I was about ten when I got that kit first - it was made in the USSR. Of course I glued it together as good as I could, then I painted it with automotive paints - blue and silver. Then I hung it under the ceiling and it dangled there in the sunlight for like twenty years. It was a royal glue bomb! I don’t like throwing away models, so one day I gave it a complete makeover - removed the paint with drain cleaner, sanded and rescribed the whole thing. And I had to vacform my own canopies, because the old parts were shot. I’m a little sorry, that I don’t have the “before” shot, but now it looks like that:
1:72 Novo Beaufighter VIF by Pawel
So - good luck with your build and have a nice day!
Paweł
Being it is only a $20.00 kitCould you by another kit and use what is good form the old?
George
Pawel
First of all, that is a fine looking Beaufighter, my friend. Fine indeed. (I also love that you vacuformed the new canopy.)
Thanks for taking time out and for the thoughtful advice.
It’s certainly worth a shot. And if it was just rescribing lines, I wouldn’t give it a second thought. My worry is that getting the rivets back will require a level of precision that I’m not capable of at the moment. If they aren’t lined up straight and spaced evenly, they’ll look awful. And it just isn’t a Grumman without them.
Worst case, I guess, is I try, hopefully learn something, and move on to plan b.
-J
If you get it saved to the point of rivets, how about a tape line to keep them straight, and mark the tape edge with a pencil dot at each point a rivet goes. Use a milimeter ruler to set the spacing. Just a quick thought.
Hello!
Well, Johnny, thanks for your kind words! I just wanted to show you, that if you want it bad enough, almost every model is saveable! As for the rivets - like I wrote, get a nice awl, sharpen it and do those rivets one at a time. If you had a surface totally smooth, then you would need a tool - usually you disassemble an old alarm clock, take a wheel out of it and use this along with a ruler to get a string of evenly spaced rivets. But since you can still see where the rivets were before you sand everything, you just deepen the rivets with the awl, one at a time, and then after sanding the rivets still show. I’m currently working on OH-6A (you can see it in the Helicopters section) where I will have to rescribe and rivet those tiny helicopters. I already started doing the rivets on the inside, in the cockpits. It isn’t vey hard to do. Good luck with your rescue and have a nice day
Paweł
Pawel: This sounds character building, but it’s worth a shot. Thanks so much for the advice and encouragement.
Goldhammer: that definitely makes sense, thanks.
George: That was my thought as well. It’s definitely not about the money. (I did even order the kit again.) There’s two lines of thought I’m mulling:
  1. The most direct path to completion would be to repair the damage. This would also hone my finishing skills. If I am unable to repair to my satisfaction, then I’m back to the new kit anyway.
  2. Now that I’ve brought it so close to completion, there are so many things I think I can improve on (especially in the cockpit) that taking a bigger picture view of the overall process might be more beneficial.
These are sort of interrelated thoughts.
Regarding Foss’s black 53, Cutting Edge decals has a discontinued sheet that comes up on Ebay and elsewhere from time to time under product # CED48120.
One thought—markings were managed at the unit level, and the guidelines weren’t all that strict (or weren’t carefully adhered to, what with fevered combat tempo and there being more important things to worry about) so there was a fair amount of variation, even within a squadron. Fun fact: Foss’s plane was originally marked “13”, but there was already a 13 at Cactus when he showed up, so they changed it to 53 in the field. From his book “Flying Marine”:
Mentioning the fact that thirteen men flew in our flight reminds me of another circumstance. I got my first Zero that day, October 13, flying the Number 13 Grumman I'd brought in from the carrier four days before. Only by that time it
had been renumbered. We made it Number 53, because there was already a Number 13 among our fighters.
Which is all to say, unless you were being particuarly fastidious (nothing wrong with that!) you could probably get away with most any stencil of the approximate style and size.
I’d just like to say how much I appreciate everyone’s encouragement. It’s really very much appreciated.
Cheers
-J
Johnny,thanks for the info on the 53 numbers, I did not know that.
I think I am going to to stay with Tamiya acrylics and future floor wax in the beginng stages of modelling , that way I can just use windex and back to the start if need be.
I think it is great having all these experenced guys here to help.
George
Hello!
Any good news, Johnny? Good luck with your build and have a nice day
Paweł
Johnny :
I have read the whole thread !
This was very interesting for many reasons . One thing is obvious , starting from a history has allowed you and your work to shine .
Now this coupled with your perserverence and indomitable spirit to do it well , has resulted in a fine looking Aircraft . My hat is off to you . T.B.
TB: thanks much. The historical grounding and focus on representing a particular prototype at a specific moment really has influenced how I’ve approached this, in a way that I see as being positive. I reckon I just need to get my executional abilities dialed in…
Pawel: Thanks for checking in, my friend. That’s very kind. As a matter of fact I’ve been cracking away at it, starting with trying your advice.
If it was just a matter of rescribing, it would be no big deal, but getting those rivets clean enough was beyond me. Part of the problem was that, while there was still indentations (for the most part), the details on the surface kind of mushed around a little, so following the original detail looked sloppy.
I’ve worked way too hard on this to settle for mushy detail on the tops of the wings.
So I’m back to the start, more or less. I can salvage a lot of the details, which will save time. I thought about doing the cockpit and wheel wells straight out of the box so I’d be back where I was in a weekend or so, but what’s the fun in that? I was going to wait until I was a little farther along to post, but here’s an update.
Round 2: Into the rabbit hole!
First thing is to go back to the refs, and start sorting out what’s what. I want to get crisp, clear and deliberate looking detail. That means I need to know what everything is, or at least what it is actually supposed to look like.
F4F Walkaround is a good overview. Also, the National Aviation Museum has a good selection of virtual tours:
I made screenshots and annotated to help me clarify detail and decide what needs addressing in the kit.
I started with the electrical panel on the starboard side console, which comes as a blank surface when it’s filled with switches and knobs. I’m assuming Tamiya originally intended this to be a decal, but somehow didn’t impliment. I used .005" Evergreen sheet stock, and poked holes for the switches, which are made from sprue stretched to .004" (a little less than 1/4" diameter at 1/48), and used a Micro-mark punch to make holes for the voltmeter (on the left) and the larger knobs, which are .030" rod. After I took this shot, I added a switch cover on the top. The detail is still a bit vague, so I might try doing this again.
I’ve been reading up on DIY photoetching, so maybe that’s a way to get really tight details for something like this. Or maybe I just need to realize that that box is 0.24 x 0.075" and there’s a finite amount of clarity you can realistically squeeze in?
After careful review of my refs, the port side console needs modifying as well. The supercharger lever (on the left pointing up) in every Wildcat cockpit shot is a shaft with round knob, but it’s modeled square with a handle. That’s going to have to go. Also, the elevator tab handle (lever pointed down) is way too long.
A JLC razor saw (A little xmas present to myself… love!) makes quick work of the super charger. For the elevator trim, I cut off the last third or so (just eyeballing it) and then filed down the taper a little. A bit of stretched sprue forms the knob.
Here’s the new supercharger lever. The pivot is punched .020" stock and the lever itself is aluminum tubing with CA for the ball. The ball is a bit big and a little off center, so I’m going to redo. The F4F has another bank of levers that sits kind of below the trottle which is not represented at all in the kit, so I’m going to scratch build.
There’s another issue with this area, which is that it’s pretty much impossible to get the two parts that make up the left console together without a visible joint and on the prototype that whole surface is one big piece. I’ve mostly filled it here, but then finally decided that the two controls aft of the rudder tab (the big chunky knob next to the throttle) aren’t really sharply modeled enough to be worth preserving, so I cut them off. A dab of Mr Surfacer 500, a bit of light sanding, and now it’s smooth. I’m going to recreate the controls later.
The rudder pedals get coils of stretched sprue to represent the springs. Way over scale, but you’ll barely be able to see and after they’re painted a have a dirty wash shouldn’t be glaring. Not a high priority, but I might redo with finer sprue to get closer. After I took this shot I fixed the smudge on the right rudder pedal and then sanded down the walls a little to get them a little slimmer.
I also added a bit of stretched sprue to represent the needle on the dial at the top. The other two indicaters will probably get decals, especially since they’re in the murk.
This always bugged me but I couldn’t think of a good way to deal last time. The control stick has the trigger molded on the top, but on the prototype it’s in front, so you’d use your trigger finger. To address, I drilled a hole with an #80 bit and then glued in a bit of stretched sprue. After trimming and sanding to shape, it’s a trigger. I then filed off the top button.
So… down the rabbit hole. Next up should be refining the details, possibly trying to beat the work on some items, such as the electrical box, and then starting to pull together. I’ve got a bunch of solder and lead wire in various sizes and am going to try to get as much of the plumbing in as I can. I sort of impressionistically added a bit here and there last time, but I want to get a lot more deliberate about it. It’s one of the things that gives those cockpits their look.
Thanks for looking!
-J
Update
Considering the above laquer thinner mishap and my generally pokey build pace, rather than try to document rebuilding this along the way, I decided to abandon the rolling WIP, and just post when I had made actual progress.
9 and a half months later…
January-February
I got a bit obsessed with that stupid electrical box, and ended up making five or six versions using different approaches, trying to get the detail crisp enough. I still don’t love final result, but i’m over it, and besides, it’s not exactly a focal point of the finished model. But I learned a lot about scratch building details, which made it worth it to me.
Naturally, I don’t have in-progress photos of it.
I do remember thinking about it a lot, imagining the structure of it, thinking about all the details, and in my mind it would seem to be large enough to require internal support. Then I realized that the longest dimension was slightly less than .25”.
I did attempt to photo etch a few parts, including for the electrical box, and the firewall. This was not successful, exactly, but kind of fascinating. I’m going to come back to DIY photo-etching later.
March - April
After finally giving up on photo etching, inspired by bvallot’s lovely F4F-3 conversion (http://cs.finescale.com/fsm/modeling_subjects/f/2/t/173752.aspx), I splurged on the Eduard PE set for the HobbyBoss kit.
It’s not very visible in the finished model, so this was almost as much to get better at learning how to work with photo etch parts as anything. I mostly used Gator Grip to tack down the parts, and then thin CA after to fix them. The Gator Grip is easier to work with, in that it’s slow, but the bond isn’t that strong and the material itself has bulk. But when excess glue squeezes out, it’s easy to clean.
“The BUG” PE folding tool helped with the bends. This is one of those tools who’s utility and merit are not obvious (at least they weren’t to me) until you try it.
The gun ports are kind of poorly rendered out of the box, and since I intended to replace the guns with aluminum tubing from Albion, I decided to fill them and then drill the holes. I tried using Milliput to fill, which didn’t really work because the chunks didn’t really bond completely with the plastic and would just pop out when drilling. The proper way would probably be to use CA with a filler, sand smooth, and then rescribe everything obliterated by the sanding.
In the end I ended up living with the ports more or less as rendered, if cleaned up a little.
I also decided at the time that it would make sense to add the gun barrels at the end, after assembly and painting, and so included styrene anchor points but not the barrels themselves. Spoiler! It does not make sense to do it this way. My rationale was that I’d save myself masking. Masking is super easy. Aligning aluminum tubes before the wings are assembled is super easy. Trying to get them seated after? Not so much.
The firewall painted, with the engine mount added, following bvallot’s playbook. I added various cables and conduits later, and then gave it a wash and dry brushed the details.
Paint! Masks!
The paint is Mr Paint. I really like how it goes on. I’m not going to say it’s better than Tamiya with Tamiya lacquer thinner, but it’s pretty good. The colors (at least Blue Grey and Sky Grey) are spot on. Part of it, is that it’s a lot thinner than I was used to, at least from mixing Tamiya 50:50 with thinner, so you have to use lower pressure and paint closer to keep it from splatting out. Being so thin, you have to work up color in passes, which is good or bad, depending.
The insignia masks are from Miracle Masks. The other day I reached out to Mel with a technical question about masks for my next project, but he says he’s not doing custom masks anymore. This is a bummer. Does anyone know a good source for custom masks?
I really don’t want to use decals, so I’m going to try Maketar masks, using an assortment of roundels and code letters/numbers, but I liked how I could get odd shaped characters for the ID number.
Here with the white elements painted, but not yet the insignia blue. I really like the painted roundels so much better than decals.
May-June
All glossed up with the popular floor care product, getting ready for weathering.
The upper landing gear struts as rendered in the kit are a bit impressionistic. I scratch built new with brass rod and styrene. These aren’t perfect, but are a bit closer to the prototype. Again, this is as much for learning as making an impact with the finished work.
July
A work trip to London and a family vacation in Wyoming pretty much took care of July.
August
Panel line wash. I used Windsor Oils Lamp Black thinned in mineral spirits. There’s something about the purpose developed weathering products that kind of rubs me the wrong way. I’m sure they’re amazing. Maybe I’m just old fashioned. Or maybe I’d be more open to them if I felt like I had mastery of the process.
I also just love the smell of oil paints and mineral spirits. My dad is a professional fine artist, and so I grew up with those smells.
Note the faded ailerons. All the fabric surfaces got that treatment, which I did by mixing MRP Sky Grey into the Blue Grey, approx 40/60 and then trying to barely mist it.
As to verisimilitude, I have a reference showing an F4F with radically faded fabric surfaces. My rationale in this case has a little back story: my grandfather was part of an advance echelon of VMF-121, arriving on Guadalcanal on 25 September, 1942, and flying with VMF-223 and VMF-224. The rest of VMF-121 arrived in New Caledonia on 29 September and then onto Cactus in October.
My intention is to show this aircraft as it would have appeared on the morning of November 7 (the day he ditched this plane off of Malaita after strafing a Japanese destroyer). So the great likelihood is that, by that time, it had been in theatre—either in combat if it came with my grandfather’s group, or in training if it came with the rest of the squadron—for at least 6 weeks. The average duty life of an F4F on Guadalcanal in the fall of 1942 was maybe two weeks, so this would have been a comparatively seasoned aircraft.
(Of course, it’s just as likely that this aircraft was a reinforcement, and could have been fresh out of the factory and dropped off the day before.)
And the bottom. Trying to bring out all that lovely rivet detail.
Dot filters. Again, I used oil paints. Anyone who’s ever done a dot filter will note that the yellow is going to make the blue look green. Oops.
When planning a filter, have a look at a color wheel and give some thought as to how you want to shape the color. It’s not just about modulation for it’s own sake, but in modulating for a particular effect. The brown, white, and grey all looked good, but I went through most of a box of q-tips getting rid of the greenish-yellow.
Engine details peek out of the of the cowling.
Pause for a work trip to Africa…
September
Just as I was putting final touches, a small sorting box fell on it, breaking both antenna posts and knocking off the canopy and windscreen.
Instead of trying to repair the plastic parts and always worry about them breaking, I decided to fabricate new with brass, by taking rod with the diameter a little bigger than the widest point of the post and filing down. This worked pretty well, and was easier than it sounds. The main post is epoxied to the bottom of the fuselage and then then hole is filled with milliput. For the small post on the tail, once I had it shaped, I chucked it into a cordless drill, and kind of crudely ‘lathed’ a pin for it to insert into the plastic. Then I faired that in with Milliput.
Fixing the paint job was a pain—there’s maybe 8 steps: basic camo, acrylic gloss, oil panel line, acrylic gloss, oil filter, dull coat, dry pigment, dull coat. A lot of these need to dry overnight before moving on to the next step, so working a few nights a week it took over two weeks to get back to zero.
As long as I was here, I decided to take another pass at the windscreen, trying to get the lines tighter and crisper. Someday I’m going to rule a masking canopies. My first pass was with Montex masks. They didn’t really fit all well, but that’s probably more to do with the canopy being a Squadron vac canopy instead of the kit part.
I have really mixed feelings about commercial canopy masks. On the one hand, I see how they save a lot of time. On the other, I think masking a canopy is kind of a fundamental skill. Maybe once I’ve mastered doing it, I’ll feel better about taking shortcuts.
It’s a mix of regular and bendy Tamiya tape. I punched the curved bar at the top of the front panel with the appropriate sized Micro Mark punch and then filled in the straightaways. To do inside and out took a night and a half.
Pause there for another trip to Africa, but I’m almost done. Really.
Thanks for looking (and making it through this absurdly long post!).
-J
Johnny - I’m glad you have revived this! It’s been a long time, but good models take time, and your Wildcat looks good! It would be better posting this one step at a time, but I see you have been busy. Thanks for sharing and have a nice day
Paweł
