X-15A-2 Rocket Plane (pics redone)
North American Aviation built 3 of the X-15 rocket powered research aircraft, serial #s 66670, 66671 and 66672. The 31st flight of an X-15 was on November 9, 1962, and utilized the #2 airframe. The throttle stuck at 35% thrust and the pilot, Jack McKay, made a harder than usual touch down, causing the left main skid to collapse, causing the plane to flip over and it was severely damaged. A decision was made to rebuild the plane with the addition of a 29 inch plug in the center of the fuselage, as well as to add the capability to carry external fuel tanks. The canopy windows were changed from the original rectangular shape to an oval shape. An eyelid or shutter was added to the port window so it could be covered in flight to avoid damage when external ablative coating seared off during the hottest part of the flight. Several other small airframe changes were made as well.
This version of the plane set the maximum speed record of Mach 6.70 or 4,520 mph on October 3, 1967. That is 6,629 feet or 1.25 miles every second.
My model is 1/72 scale and is made from the Monogram kit. It is painted with Model Master enamel paint and uses the kit decals. The external tanks had several different paint schemes at different times, including several with a bunch of Day-Glo Orange. I took the easy way out and used the two tone silver. Someday I would like to build the NB-52 Mothership to go with this model. [alien]
Nice job, yardbird !
The X-15 has always been one of my faves (even though it’s not WW II !)
At first, I thought it was the 1/48 Special Hobby kit. Great work in the small scale ! Well done.
nice. you do great work.
joe
Very nice Yardbird…good history on it as well. Thanks for sharing your little gem!
Joe
YB78 - A great example of a record setting aircraft!! Nice work, my friend!!
I remember as a youth clipping out pics from the newspaper of any, and every, mention of an X-15, but alas, they have long since disappeared (or maybe not; that old scrapbook may still be lurking about).
I especially like the history that you included with your pics. It adds that extra element of your own interest, and brings us in even closer to understanding and appreciating your efforts, and your aircraft.
stinger
Yardbird,great job done on the X-15 I really like it.Digger
Very nice, Yardbird! I’ve got the 1/48 Special Hobby X-15A-2 and I hope mine eventually comes out as nice as yours!
nice build!!! wow that thing is fast!
Very nice build Yardbird. I haven’t seen that kit in ages, but you did her proud. Thanks for sharing.
Regards, Rick
“X”-cellent looking build, Yardbird…well done!
Regards, Dan
You do good work Darwin, thanks for the pics…
