I just purchased a 1/32 Roden Sopwith Tripalne. It has the windscreen printed on a piece of clear acetate. Since I will purchase other WW1 kits, I have the following four part question:
What is the best way to:
remove the windscreen from the acetate sheet;
paint the windscreen frame;
attach it to the fuselage as it has such a narrow attachment area; and,
curve the windscreen (in other kits) if necessary.
To answer your questions in order.
I use a small pair of curved sissors.
I run a sharpie marker along the edge. At that scale the edge is not very pronounced. Sometimes at 1/32 you’ll find a PE part for the frame. In that case paint the frame then attach the acetate with clear parts cement
I use clear parts cement and a piece of stretched sprue as an applicator.
I curve the acetate gently between my fingers. The body temp and a little patience is enough to gently curve the windshield to fit.
I build mostly in 1/48 but these techniques worked just fine on the Encore 1/32 Albatros DIII and SE-5a I built for the Nuremburg Toy Fair. I hope these ideas help
