Wright R3350 engines
Hey guys i’m hopeing you can help here, i’m trying to source some AM resin R3350 engines for an upcoming build, is there company that makes these???
You don’t say what scale. In 1/72 these are available from Engines and Things #72004. In 1/48, I can’t think of any, but you can source them from the Monogram B-29 kit.
I looked into this once before also. IIRC, I thought engines and things made them in 1/48th also. Regardless, E&T resin engines have the reputation of being some of the worse resin parts out there are far as quality of detail and molding, to be avoided.
If you source the Monogram B-29 kit all you’ll have is the front row of cylinders. Myself, I wanted a resin replacement on par with those made by Neomega so I could uncowl one of the planes engines for a dio. I’m still looking for a good resin 3350.
Any Skyraider kit should deliver something.
Thanks for the input guys[Y] Sorry for not mentioning the scale, it is 1/48…
Bondo i think your on to something there, it may be a better alternative to grab a Tamiya Skyraider for it’s engine…It could get a little pricey if i want to replace all four though[^o)] but then i’ll only ever build the one B-29…
