While I was working on my 105mm LeFH18(sf) auf Geschutzwagen 39(H) from Trumpeter, I came across a real ugly looking part that was suppose to be a drive shaft. The alignment of the kit’s component was also bothering me.
So I decided to make tiny working U-Joints. [:D] It will fix the alignment problem and looks better at the same time.
I first tried with styrene, but it was too flimsy. I wanted then to use PE… too hard to drill… I used aluminum foil (the same as a pizza plate) and cut a long 1/8 strip, and then made several little cuts of 5/16 long, rounded off the corners, and curved it while keeping the end straight.
I then drilled a hole on both sides. I used a piece of wire, inserted it in, then roughed the end to make a mushroom head to avoid to glue the pin in the aluminum brace. When 2 were completed, I just glued the 2 wires together at 90 degres. ET VOILA!! A working miniature U-Joint. [:D]
Is there no Macro mode on your camera ? I can see something, but I’m affraid it’s too small to say something usefull about them.
However, if you’re talking about that allignment problem, are you absolutely sure that is is a mistake ? The reason I ask is that I’ve read something similar on another thread, but it turned out to be ment this way.
Yes there is Dan, and I was using it. These 2 shots were the best of a serie of about 20. I think I might need more practice with it however.
Not sure at all. But the pictures I found from the vehicle in Saumur shows that the shaft is almost parallel with the hull side.
I looked at comparision between both the Bronco and Trumpeter’s offering on http://www.perthmilitarymodelling.com/ , and they show a missalignement indeed. However, mine looked a tad more off than shown in their review and just painfull to look at.
I guess I could had fixed it by sanding the left side of the rear panel and then fill in the resulting gap on right side, a pain in the neck IMO, but I wanted something better looking than that kit part.
Keeping in mind that this one is a opened top SPG with a lot of the interior that will be seen, it seemed the best course of action for me.
