Currently working on this M4, what do you guys think?
Hello!
It’s very nice - a nice clean build. Like one of our ex-members used to say it - needs more rust :-). But not really rust, maybe some dirt would be OK. And it is too green - US Olive drab was supposed to be a mix of black and ochre, so for your future builds try using some colour that’s darker and more gray-brown oriented. Anyhow, I like your model a lot - congratulations on a very nice build. Thanks for sharing and have a nice day
Paweł
Very nice! Mike
Looks great lando! I like your dry brushing. If your open, like Pawel said, now is the time to add some dirt dust and other nastiness that AFV’s kinda have to get into.
Kinda like this, but maybe not as much. This one is going through a field during the spring thaw.
I did lots of research on OD, so I went with the Tamiya OD and dark yellow mixture but I think I got the new batch of OD wich looks a little more green color, im leaving it the way it is, now to get it dirty and maybe put it in a Dio
Like the others wrote, now is the time to add the dirt. You should also tie down that stowage. There is no way the extra road wheel and jerry can on the engine deck, for example, are going to stay put once the vehicle starts moving.
Looking good. I would not worry too much about the shade of OD or the mud/dirt. But I would suggest something to tone down the bumper codes, the look pretty bright compared to the rest of the tank. An air ID star would be in order. While the ones visible from the ground were painted over by late war, the turret roof and engine deck stars were usually there to reduce the chance of friendly air attack. TC hatch vision blocks could use some color- clear green or clear blue are my preferences for that… Think of old coke bottles for how armored glass looks. One last pointer-add an antenna, either wire or stretched sprue. All those little things will add up and kick your build up to the next level. It’s very nice, but can look even better!
Did some mud and dirt action, I still need to put more ammo boxes and antenna
That tarp on the fender could use some work!http://filmoff.net/engine/data/emoticons/on_the_quiet.gif
…wouldn’t take much.
Observe how that fold on the end just doesn’t look too convincing.
!http://www.kolobok.us/smiles/artists/snoozer/pepper.gifThere’s still a few other nick nacks that need some work but I like how it’s all coming along.
Don’t forget that lifting fixture on the glacis.
Thanks for the feedback, i still have lots of work to do, I need to get some decals
If you’re gonna add dirt and mud, the tracks tend to throw up a lot that gets stuck on the rear hull deck, sides and rear vertical plate due to a “rooster tail” effect as the tank is moving… Have a look at some photos of real tanks to see what I mean. Especially in Europe, a very muddy place!
Hi. nice done but i would use more dust and rust pignents for make it more used and old. and my be add some equipment on the board (different boxes, buctets etc. ) for examle you can see how i did it cs.finescale.com/…/162403.aspx
I really like how she’s coming out and good advice from the guys here!
That’s a great looking Sherm Vlad. How did I miss that?
Thanks guys for the advice, Vlad your Sherman looks great
Yes,
that build was totally hot!
