So now that many of us are working from home, and have no where to go when we are not working. I find my benchtime is significantly increased, so much so that I will finish a model in less than a month. I started this a few weeks ago, GWH’s 1/48 FW189 Night fighter version.
Haven’t detailed a good cockpit in a while, and since this plane’s has a lot, I mean a lot of glass, it would be a good choice as you can see so much.
The cockpit builds up nice, but man, that’s a lot of ejector pin marks, I filled some of them in, others I left as they will be hidden with equipment or just not easily seen. The kit has a limited PE sheet, but decided to go old school and scratch build details with plastic stock, wiring, drilling, leftover PE, etc…
The belts and pedals are from the kit, the oxygen cansisters are from german army cansisters, the big ammo box is from a 1/35 armor pe set, the oxygen bottles are just plastic stock.
Added some pedal lines, misc PE scraps, drilled out the support behind the pilot seat, and detailed the camera with palastic strips.
Twisted electrical wiring, misc pieces left from the junk box, and plastic card for missing consoles based on reference photos.
The extra consoles are from a really old reheat PE set and their generic decal sheet, Solder added for piping. Added a ‘doodad’ I saw in a picture with a shelf, I think it’s the motor to moves the camera.
There’s a nastly seam where you join the top and bottom of the side pieces. Filled and sand where I could, the rest I left as they are hard to see.
Here’s the cockpit primed with black and then painted german gray
Sprayed lighter shades of gray in the panel centers and picked out highlights with even lighter gray.
Finished up brushpainting the details and added chipping
sidewall switches added and painted
the other sidewall added flares from plastic rod, looks a bit crude close up, but ok in ‘real life’
Completed cockpit, painted the camera an off-white as that seems to the correct color. Added some oil pin wash and a little pigments to dirty things up. The gunner’s pad is from a cotton pad stiffened with diluted white glue.
Ok, that’s it for now. Have some picture of the rest of the cockpit and the plane is actually closed up. Will put more pics up this weekend.
