Wife said i had to re paint the holiday display...
Perfect weather conditions!
what scale is that :slight_smile:
Needs more weathering [:P]
Not enough rust [whstl]
It was already weathered so I had to freshen it up!
Olive drab over neutral gray, or natural metal finish?
I asked the wife for Luftwaffle mottle,but she nixed the idea!
Does Santa use FS or RAL colors? [:O]
Did you match the colors to paint chips in the Official Monogram Santa’s North Pole Color Guide? [:P]
No man I am not one of Those modelers!I am an Anti rivet counter/color obsessive!
Verlinden makes a nice PE detail kit for that.
Wow!must be pricey!
What?! No preshading???
No panel lines either(Plywood construction)
Philo: looks like you used RLM colors…did you use red lead or red oxide primer? BTW, nice white wash.
I suggest setting your router at a shallow setting and plow some panel lines. A nice med grey wash on the lines will add some depth. How many gallons of Alclad will that project take if you decide to go NMF?[proplr]
Yeah it might take 2 gallons!
For the instrument panel, will you be using the kit one with the decal, or are you going aftermarket?[:D]
He could dry brush the details [^o)]
That usually works well on the old Monogram kits.[:D]
You guys are funny!
The nose profile isn’t right. Was this made by the ChiComs? The manufacturer should have asked me for my help since I know a guy who dated the sister who cut the hair for the mailman of the actual elf who worked on the original.
