Wicker Seats
Anyone know where I can get 1/48 scale wicker seats for WWI era fighters?
scoured google, nothing but 1 czhech company… [and no pics!]
thanks
-sean
Sean:
While they aren’t real wicker, they’re the next best thing: Eduard makes a 1:48 scale fret of all types of WW I seats (No. 48 357), including wicker, aluminum and padded seats (the latter require a little epoxy putty to make them look accurate). These seats work great (remember to anneal them for a few seconds, then air cool them – do NOT dunk in water – so when you bend the back part around the seat portion, it won’t spring back on you).
And while you are at it, Eduard also make a fret or two of all types and sizes of wire wheels (48 505), frets of fuselage stitching, and every nation and scale of color WW I seatbelts (they are just adding 1/72 WW I belts to the line), and even a fret containing turnbuckles, control horns, and other rigging hardware. You can get it at a discount in the WW I Big Ed set which contains all of these frets in 1/48.
TOM
I use Curad fabric bandages for that…
If you want to check out the Eduard PE wicker seats, go to www.eduard.com. Go to the search bug and type in the fret numbers I gave you. It will give you a photo of the fret of seats and you can get a better look by downloading the PDF file of the instructions, a service Eduard offers for all its products, including kits. Good to know if you lose one page for a PE fret, or the whole instruction booklet for a kit.
Also, if you are hell-bent on making them out of something like wicker, there’s probably somebody on the WW I site www.aerodrome.com who can tell you how. Frankly, I think it’s a little impracticle below 1/32 scale, but somebody on Aerodrome will have done it, you can almost bet on it. The Curad bandage idea is intriguing. I’d like to know how you do it so I can perhaps give it a shot.
TOM
I just cut pieces to fit the kits’ seat and stick 'em on. They’re already the right color, as far as I can tell, and the texture gives it some depth. I tried doing a weave with thin strips of bandage, but it ended up looking like a lawn chair, so I went for suggestion rather than duplication. In that small of a scale, it’s all I felt I needed… I’m always on the lookout for stuff that “looks miniature”, rather than buying aftermarket stuff. A piece of nylon stocking works as well, stretched over the seat tightly and then covered in liquid cement to set it.
Aeroclub make white metal ones:
http://www.aeroclub-models.com/p.html?n=21&c=V127
Obvioulsy, a certain amount of creative painting will be required.
Cheers,
Chris.
Greetings all scratchbuilding wicker seats involved weaving copper or brass wire throught a series of vertical rods imbedded at one end in a seat base. I know several modelers that do this.
Scratchbuilding,… hmmm, I had considered it [there is a 1/32 scale DR.I in the pile somewhere… ] but check this article out [seat looks great, but 3 weeks…!]
http://www.ipmsstockholm.org/magazine/2006/12/stuff_qvarfordt_dh2.htm
Here is the link to the site I found with the seats… http://www.sweb.cz/hippomodels/
You are probably right, looking for something that “looks” like wicker in that scale would be more practical…
But I’ll see if I can get hippomodels to send me some pics of the seats…
-sean
Wickers were found in some British aircraft like the Sopwith F.1 & 2F.1 Camel. The Fokker Dr.I used a seat that had a wooden base with a pressed aluminum backing. The inside of the backing was covered in linen.
Kindered spirit! I also prefer improvisation over ‘after-market’ items. I find it especially satisfying to solve detailization problems that way.
Excellent idea for the seats!
I just had an idea… hopefully brilliant!Building on your idea, Hans…
  • build a miniature loom with “T-pins” and a small chunk of wood, any needle will work as the shuttle… I’m thinking the “rope” that ship builders use would work nicely [though the fishing line looked good]
  • make a paper template from existing seat
  • seal your “fabric” with white glue, wait, template and cut…
  • stick onto your plastic seat… :slight_smile:
  • if you are worried about the back of seat being seen, make 2 fabrics!!
thoughts? - seems to me that would be much faster/easer than the 3 week method!
-sean
