In cars WIP I see many people voluntarily removing chrome from already chromed parts (using various methods) and putting it back afterward with either paint or something else (also various methods used here too).
I was wondering : why would you do that ?
Just asking out of pure sheer curiosity, not trying to start a heated debate here. [;)]
Because kit plating is out of scale (too thick), not realistically shinny and many times not the smoothest. Alclad as well as other paint on plating offer many shades of chrome, polished aluminum, brushed aluminum and other metallic shades. The can be applied much thinner also to look more in scale, just to name a few of the reasons.
Another reason is that the sprue attachment areas are frequently in spots that show, and then lack the chrome finish.
Personally I do not remove the chrome. It can be primed, undercoated and then Alclad. Or, if the sprue area is small enough, there are some good chrome/silver paints that can touch up small spots.
Don, that’s exactly what I decided to do on the truck I’m building. Sprue marks are small enough that a touch-up with chrome silver will do for me.
I have had a few kits that have had some very realistic plating. It was quite thin looking and had the appearance more like polished metal or a satin finish. Too bad more plating can’t be done like that.
It depends on the particular kit on whether or not the chrome comes off or not. Newer kits seem to have a bit better chroming that is thinner (I think most of that is what’s used under the chrome). I tend to strip the older kits as the chrome really softens the details that can be revealed and better-displayed if covered with something like Alclad. But yeah, it really depends on how the chrome looks on a specific kit.
Do you mean the chrome parts or the whole kit? Epoxy will work, but I don’t see the advantage for most of the kits. For the chrome parts, you need to remove the chrome from the gluing surface (usually the bond of the plating is not really strong enough to rely on), so you can glue the part with anything that will stick to styrene. If you glue the part with epoxy, without removing plating, the glue WILL stick to plating, but the plating bond is very much at risk of failing if it is a big part. If it is a small part, you can get away with it without removing plating, but in that case CA will work also, and is easier (and smells better) than epoxy.
I have to ask you. Is the kit you’re building New? The reason I ask is this . Many older straight MONOGRAM kits had a tendency to have Chrome plating disappear over time. I don’t know if it was oxidation or what . My 70 Malibu looked kind of funny with yellow plastic showing through the chrome.
Unlike many, I do Not use Alclad in any build . I use foil Chrome exclusively . Or if it’s for a contest build then I send them to Chrome -Tech, inc. For that professional touch . This requires stripping all the original plating off . For a few bucks more they will do set-up and stripping for you .
In case you ask. I use the cheapest , shiniest foil I can find and then make my own . Yes, I do use " Bare-Metal " foiling too . It just depends how many colors of aluminum I want to represent on a natural metal airplane .
As far as scale thickness I really didn’t know anyone was OCD enough to measure the plating thickness. I never have . After all,why is that necessary if the kit chrome is good ? As far as autos are concerned ,They could put the sprue connections in a spot harder to see . Many times it’s a line vertically cutting the bumper, say from the ends. If you trim the line off , well you’ve got a bare plastic spot.
The right shade of foil chrome , Burnished thoroughly will hide that and you can’t see the edge of the foil chrome anyway, Unless you use a magnifier . Only OCD judges do that . T.B.
The very first thing I do when building a new car kit is BOOM!–sink the chrome parts in bleach, and usually within 1/2 hour I have nice bare plastic. Quick, easy, and then oh-so-much easier to work with. Not only can you easily glue pieces without the mess, hassle, and waiting time of epoxy–yuck!–but you can sand the attachment points and clean up burrs, parting lines, etc–real necessities if you’re serious about producing a high-quality build. A simple coat of Alclad imparts an amazingly bright sheen of chrome for pennies when you can do a dozen kits or more for the price of one $7.00 bottle.
The previous poster talked about using bare metal foil or sending pieces off through the mail to some re-plating company. Whatever floats your boat, but speaking for myself, I would go mental if I had to wait for parts to get back from some company when you want to get building. And having worked with bare metal foil plenty of times, I can say that this is an impractical choice for curved bumpers and pieces like manifolds and valve covers. Not to mention that BMF can have a very high “learning curve”, and it also can have adhesion problems if its old. You’re much better off getting some Alclad. You won’t believe how easy it is to use and how high quality it looks.
I saw some people putting the chromed sprues in Simple Green and let them soak for a few days before removing the excess paint with a stiff toothbrush.
Talking about Alclad (I never used it), can you hand brush it or you must use an airbrush to put a coat on the parts ?
Also, does it come in many “colors” (don’t know how to properly call this) as does it come in dark chrome, light chrome, heavy chrome, etc. ?
Jay, while you can brush paint it, and I’ve successfully done that on small parts/sections (namely a polished rim effect on a set of wheels for a car I’m building), it’s best sprayed. Like spraying, it requires several coats to build up to the desired effect. With brush painting, though, you have to wait until the previous coat is completely dry before you apply another coat.
And just like the pieces you air brush, you have to first coat the part with a gloss coat of usually black paint. If you brush that on, your brush marks will show up under the alclad.
In some kits the engines come fully chromed which doesn’t happen in real life, so I get out the oven cleaner fluid and after an hour or so it’s all gone. I can then paint the engine in more traditional/real colours.
For me I remove it because like many have mentioned the part shouldn’t be chrome at all. For instance the Hemi cuda kits come with chrome valve covers. Many don’t realize it but they never came that way. They were painted black from the factory. Other kits will have other parts that have no business being chrome unless you are making an insane show rod. Typically axles, starters, hoses, intakes, etc are not chrome. Thats what drives me nuts about AMT’s Semi Trucks. When have you seen a Semi with chrome drive shafts!??!?
The most important reason for application is it lessens the chance of flaking when you paint it the correct color. Paint doesn’t tend to bond very strong to the chrome surface even if you use primer, and will flake and wear on the edgeds. Removing the chrome and “roughing” it up a bit with very fine steel wool creates the perfect surface for paint to adhere to.
I’m tackling a car kit for the first time since, oh, dinosaurs roamed the earth, and decided the chromed parts were too … chromy/shiny/whatever.
I’ve tried soaking the parts in bleach, going on two hours now, and some of the chrome - mainly on the large flat areas, is staying stubbornly attached. On fine details like grills and vents, it came right off. Suggestions?
I remove it for the reasons Pat mentioned, however I leave it where it would be on the real thing. This model had chrome cylinder heads, crank case and trans cases. (wrong). I stripped those and painted them with Alclad II to look like aluminum. The pipes on the other hand look right left plated.
All model “chrome” plating is not equal. Some comes right off, others are a bear to get loose. I’ve tried about everything except purple powder, which is said to work well.
Try spray oven cleaner. Most of those kinds of things are lye based and are quite caustic so wear gloves.
