[%-)] I have an aztec airbrushmade by testors[B)]. I am going to get an Iwata one. What airbrush is better a iwata revolution hp-cr or an iwata eclipse hp-cs?[:D]
what’s the diffrence between the 2
Well, the CR will give you a more specified use, as in it is made to do one thing, moderate to pretty fine detail while being able to spray thicker stuff. The CS, however, is a wide range tool that does a variety of applications and sizes well. The CS will spray higher volumes, but the CR gives you slightly more detail.
I would go with the CR, but it’s really a toss-up if you ask me.
Get whatever’s cheaper, but if it’s only by $10 or less, go with the CR.
i can get the cr plainfor 65 or in a set for 89
or i can get the cs for 89 which is best for german armor
I would get the CR set, then.
