I was wondering , would there be a way to show on the board statistics , when you moused over ones screen name it could show you what forum that person is currently in? seems it would make it a little easier to locate someone if you had a question for that person if you seen they were on line? i know some of us bounce around from time to time i just thought it would make it simpler to find someone?
thanks.[:D][:D]
The only problem that I can see with that suggestion is the speed at which the system would have to poll the individual users for location, then post those results to the end user. The inherent latency in such an operation would mean that in the time it takes for you to get the results of your search, the person probably moved on, anyway. It would also be quite taxing for the servers, resulting in much slower responses and longer load times for articles, forums, etc. Great concept, but almost impossible to implement efficiently.
demono69
i guess us ‘ARM CHAIR BILL GATES’ guys should just stick to building models, thanks for the reply .
