When was the last B-52D removed from service???
Yesterday, I picked up a 1/72 Monogram B-52D for $17.00 and a 1/72 B-1B Lancer for $12.00 that were part of an estate sale at a military model show!!!
I’m hoping to build both of these models and integrate them into my 1/64th scale model train layout, which centers around Burlington Northern’s Marinas Pass operations in mid/late 1980’s.
Specifically, I hope to have these aircraft flying overhead on a training mission while the trains work below.
In order to make sure I can make everything fit into the timeline, I need to know when the last B-52D was removed from active service and, if this model of the venerable B-52 was still in service in 1986, what paint schemes were being employed and what external modifications had been made.
Do any of you know if the B-52D was still in service in 1986 and, if it was, what it looked like at this time?
Furthermore, if the B-52D was not in service at this time, how difficult would it be to modify the Monogram B-52D into a model of the B-52 that was in service at this time?
This may help with the timeline:
http://www.joebaugher.com/usaf_bombers/b52.html
It looks like by 1986 all the -D models were in the boneyard or museums.
Greatmodels.com has a resin conversion set to make that D into an H. I have the set myself but have not attempted to use it yet, so I have no idea how well it works.
Thank you DMK,
According to the link you provided, “the final phaseout of the B-52D took place in 1982/83 when over 50 were sent to storage.”
Would you happen to know what the B-52D’s looked like in the early 80’s, specifically, if any external modifications had been made and what paint scheme they were wearing?
Also, while continuing my search, I found that the Air Force constructed a B-52 simulator in two railcars!
As I mentioned previously, I’m hoping to integrate this model into a model train layout and these cars are just neat!!!
After I finish the B-52, I’m thinking I’ll try to build a model of this simulator.
http://www.wildfire-productions.com/atd/
http://www.trainboard.com/railimages/showphoto.php/photo/61112/ppuser/blog.php?do=list
http://www.gingerb.com/CNJ%20Buttonwood%20PRR%20Yard%20USAF%20Train%20NOV%201967.jpg
The USAF stopped the ARC LIGHT sorties over South East Asia in late 73 or early 74. Shortly after that, they took 80 of the best shape D models and sent them through an extensive rehab program where they were disassembled into basic components and had major repair and replacement procedures done to them. This did not show anything external other than a fresh paint job, which was the same three tone camo on top with black belly and vertical stab.
Darwin, O.F. [aln]
I was assigned to the 43rd Strategic Wing on Guam from Nov 78 to July 1980. When I left, I had not seen any other paint job on any B-52 beside the SEA camo over a black frame. I think the D models were all parked permenantly in 82. BYT, having said that, it’s your world, build what you want. I personally like the the D model the best.
Paul
My old friend Airman Jim crewed on ferry flights down to Tucson. He had a ride on one.
“What’s wrong with this aircraft, sir?”
“Cracked wing spar”.
