I just wanted to know what’s you order of painting tools on the tanks. Do you build the model and put everything on except the tools and paint it and then put on the pre-painted tools after? Or do you put the tools on with everything and just paint it all and detail the tools after basecoat? I put the tools and cables on the model after the basecoat and camo, just because it’s hard to spray camo around tools glued on, but I guess with 1/72 you kind of don’t have an option. just wondering…[:)]
I usually build it all unless something will get in the way. Like a jack or something thats up against another surface. I’ll leave it off so I can paint behind it. Otherwise glue it all on and paint it later. I dis-like having to scrape away paint to glue on a part… But thats just me…
I pretty much build the whole thing, details and tracks (if non-workable links) included, then paint. I hate trying to scrape off paint to glue stuff on.
If it’s a vehicle with skirts, I’ll paint the suspension, tracks, and lower hull first, then finish the build, then finish the finish.
I build the vehicle minus tools and any other bit that is not the same color as the hull first. Paint the model, add tracks, then add the prepainted tools and whatever else was left off. I use superglue for the items added back onto the vehicle. I have never had a problem with them coming off and I don’t scrape away any paint. I think it gives a cleaner finish by painting the tools, etc separate from the vehicle and adding them back later.
Same with me. In fact this may sound wierd or wasteful, but I never really use modeling glue any more. For every single thing I build I use super glue (except for indy treads-tam extra thin). No doubt whatever technique or seqence you guys use, we all turn out great models anyway, so I guess it’s just preference…
I add all the tools and paint them after I have painted the tank. I used to paint the tools while they were still on the sprue, but I always screwed up the tanks paint with glue spots when I tried to put the tools on the kit.
I always paint the model and camo it first. I add the tools just before I chi and weather it. I have a nasty habit of bumping off parts I glued on, so the less time they are on the better
