what type of paint to use
I have bought a new paasche vl air brush and compressor what I need to know is what is the best type of paint to use and the best way to mix it. I have been using model master enamel and mixing it with the MM thinner. Also I would like some tips on using a double action air brush. I had a testor single action air brush and compressor combo that I had got half way good with but it did not let me do some of the things I think I want to try. Any help would be great thanks. medic1098
You’re comfortable with MM, so stay with it. However, save yourself a lot of money by getting your thinner by the gallon at the hardware store.
As far as airbrush use, you have the basics, so just load up some paint, take a junker or even some sheet stock and practice getting the right pressure to pull back on the trigger to get the lines you want.
[#ditto]
For that matter, you can also decant some Krylon paint you get at Wal-Mart in the same section as the paint thinner and have fun with that also.
If you decide to spray with MM acrylics, as I do so I can stay indoors for the most part, I have found that the generic Wal-Mart regular fingernail polish remover is an excellent air-brush cleaner, since it’s main ingrediant is acetone, and it also has glycerine imxed in a water-based solution that keeps the brushes O-rings from drying or swelling as alcohol will. Also, it leaves an odor that is not objectional to other family members.
Tom [C):-)]
