Hi
Everyone
I have been doing a lot of searching lately on printing my own decals. And while the ALPs printer is talked about quite a bit it seems others may be able to do the same job.
So here is why question:
What printer do you use for printing your own decals?
And maybe what brand of decal paper?
Are laser printers now viable since they can print at 600 X 2400 dpi?
Thanks
Scott
I use a Canon S9000. I have settled on the paper from Micro Mark. It has improved a lot in the past few years and I get really great decals.
White or very light decals can be a challenge. Because the entire sheet is white, you need to ordinarily trim very carefully to the outline of the decal. I set the background color to the color of the finish on the model in the area the decal will be applied to. I still try to trim closely, but I do not need to be perfect that way.
BTW, I overcoat with Testors dull or gloss coat. I apply two coats. The first is just misted on lightly. Too heavy a coat will make the inks run. Once it has a misted on coat, the second coat can be heavier.
I know it’s been a month since this was originally posted, but I use an Epson CX4800 inkjet. I love Epson’s color-brite ink. Very vivid colors that are archive quality (don’t fade or bleed).
I’ve used Testors’ decal system (paper and bonder spray) and have had really good results. I recently switched to Micro-Mark’s paper, but haven’t used it yet (hope to, in the next few days).
-Fred
