What is a Nortek Light?
Does anyone know how a Nortek light actually works?
are you sure you have the correct name?
any how nortek lights are pretty much every where nowadays if you have a wireless device. key board mouse even tvs and cameras see that light on the bottum of your wireless mouse thats a nortek
hope this helps
the one I am familiar with can be seen here notek light
http://www.google.com/images?um=1&hl=en&rlz=1T4GGLL_enUS314US314&biw=1003&bih=596&tbs=isch%3A1&sa=1&q=notek+light&aq=f&aqi=&aql=&oq=&gs_rfai=
Notek,[;)]
So now I know how to spell it , do you know how it works?
Low light, indirect lighting.
Here’s the most recognized…
!http://t3.gstatic.com/images?q=tbn:ANd9GcR6by9c0MB1yWEvvI4nXfZVfBdjDwVsXgXEpBsiPwAvy4uuBI8&t=1&usg=__1OmfOw2h98rO1PJ6XCLQl7N526s=.............fairly self explanatory.!http://www.steeldragons.net/Notek.jpg
The rear lights (below) were used mostly for estimating/judging distance behind vehicles at night.
!http://t1.gstatic.com/images?q=tbn:ANd9GcRt6e-I9yS7lqMFKGCsdWq4LVvi49ayR-a8WffDO2EvJ_g0Ub8&t=1&usg=__jWYleC6SqydVGdLDlPPIg3ORD4s=
!http://i20.photobucket.com/albums/b232/gluetank/Decorated%20images/th_T1-4-copy.jpg
All of the Notek lights were designed to be used under black-out restrictions…so the indirect lighting/hooded light concept was essential for the front light when the standard/main lights couldn’t be used to avoid being spotted from ground or aerial observers. The rear lights were used to maintain proper vehicle spacing at night under similar black-out conditions and worked on the concept of optical convergence at different distances to achieve that which is why the rectangular style light has 4 windows but the sizes of the windows are different. Depending on how far away from the light you were dictated what pattern of the 4 windows you saw and provided a constant frame of reference to avoid vehicles ramming into each other in the dark. [;)]
When following another vehicle in blackout drive, you try to see only 2 lights. If you see only 1, you are too far away and if you see all 4, you are too close.
