What have I got here
I found some Humbrol paints I forgot I had , but don’t know what they are. Two have no color name, just numbers. one is 93 andthe other matt34. the other one is HD4 Zinc Chromate Primer. can someone tell me what theyare and what they’re used on? Thanks
According to this link:
http://www.fortunecity.com/meltingpot/portland/971/reference/humbrol.htm
Humbrol 93 is Desert Yellow (FS-30266) and I suppose that Matt 34 is flat white. Zinc Chromate primer is normally either a green (most common) or yellow (less common) primer that was used for a lot of aircraft cockpits.
Thanks MusicCity, 93 must be a German color and the primer is the yellow. now to figure out what to use them on.
Well, if you can find a model of a Tweety Bird you are home free!
