What color to paint my model room floor.
I have to admit it - I have old eyes! I used to have 20/10 vision now I have bifocals and wear magnifiers. I keep dropping little bitty parts, you know tan ones, white ones, red ones, the ever fun clear and so forth. I have 70’s multi color brown 4" vinyl squares that run from off white to chocolate brown. I’m going to paint the floor but what color is most likely to allow me to find my wayward peices so I can quit having to get my daughter to find them for me. Thanks in advance
If a dedicated modeling space, maybe a light blue, a green, or another color not generally used for sprues. Night also put down a sheet, if you drop something, or it launches, better chance of finding it by gathering up the sheet and letting anything on it to migrate to the center.
Russian cockpit green!
I’m going to vote for black.
Splatter paint it. It’s going to look that way in just a while.
And it’s going to make finding that dropped part so much more difficult
I put down a white-ish vinyl tile to cover the concrete floor. I do primarily HO scale model railroading and have the same tile in the layout room. As you probably know, concrete and carpets ‘eat’ model parts and render them never to be found again. The white tiles give me contrast to at least spot something on the floor that might indicate a lost part. Rolling a flashlight across the floor is sometimes necessary to reveal non-contrasting parts. The white tiles also serve the purpose of increasing the relative light in the room by reflecting over-head lighting. Old eyes often need brightness to focus better. It worked for me. Good luck!
German ambush camo scheme would be cool.
I use cheap vinyl tiles instead of paints. I have gotten them as cheap as 25 cents each- square foot each. Must of them are an off-white, with minimal pattern. That way, if one gets too much spilled paint on it, I can just replace it, next time I find them on sale. They are adhesive backed and are easy to put down. Also easy to get back up with putty knife.
I think that this is the perfect solution. I really like the idea of being able to easily replace stained floor tiles.
I don’t think that black would be a good color for a floor. It would show every speck of dust.
And the smallest of parts. [H] Not difficult to keep up with dust.
My bench is in the cellar, and the concrete slab is painted with a medium grey deck paint. That’s OK if the kit’s material isn’t medium grey or close to it, as many styrene kits are today. I keep a small flashlight on the bench to help spot parts that have landed on the floor. Not only do I shine it down, vertically, to the floor, but I’ll also lay the flashlight on the floor and let the beam shine along it, to find a part that has fallen to the floor.
Black, to find all of those escaped tiny parts.
