What color panel liner for DAK vehicles ?
I use tamiya ts-3 for my tanks and tried mig panel liner for DAK vehicles but when i apply it I can see a lot of the ts-3 through the panel liner still(like it looks like the first coat of paint on a primer layer) am i just nost using enough? do I need a better brush(what kind)? am I supposed to put multiple layers? any help would be apperciated
thanks
I’ve never used this stuff but it sounds like its very thin. Give it a good mix and apply another coat or 2 until your happy. I use my own panel washes useing oils or AK’s wash and find with those one coat is enoughmost times but often need to add a second.
On DAK vehicles I use dark brown pin washes either my own brew from artist oils or Mig dark brown wash. You need to have a gloss acrylic barrier coat so the wash will easily flow into the sharp details. Flat finishes tend to bleed the wash and not give a clean sharp detail.
i use raw umber oils as well. sometimes i hit it with a gloss coat sometimes i don’t. i will try using a small brush and just gloss coating the panel lines and see how that works.
