Ok I have just started modeling again, after many years out. Well I just would like to know what are they used for. And not only what are they used for, but how do I use them.
Any help will be great!!
adws
adws
PE parts are used when styrene parts would be too thick and therefore out of scale, such as mesh engine covers, ship railing, ect. Also they are used where the plastic part lacks the detail which can be attained by using PE.
It is pretty simple stuff to apply in 90% of the instances you use it. Usually, remove it from its “sprue” with a sharp pair of snips, file the edge where you removed it from the sprue and glue to your model with CA (super) glue. For the other 10% bending and tweaking of the PE is necessary. I will usually place the PE under a # 11 blade and bend it up along the edge to get the desried shape. For curved shapes, I will roll the PE in my fingers. Even compound curves can be made this way, it just takes a little practice.
Good Luck
N.
Great that helps a lot. Thank you. So the biggest thing about PE parts is that they ad detail. I understand now. Thank you
adws
just one thing: use them ONLY if your experienced or feel you are. i wasn’t/didn’t and messed them up
use rubbing alcohol to rub off chemicals then apply then wash with soap and water then paint. looks great!
one kit to avoid that has photo etch is dragon ta 152 c-0
