I need help weathering an 1:48 F-14A by Hasegawa. I have just prepared the parts for painting. I will be Doing a TPS paintjob, like used on the real steel today. I have preshaded and painted the upper Body testor’s MM medium gray. How should i paint it the rest of the way? Any weathering suggestions?
Thankz in advance…
I know that the low-visibility paint on modern Tomcats gets dirty easily, and if you look at pictures of them, they have a splotchy appearance. My best guess would be to apply some dark grey pastel chalk in splotches. I’ve never weathered a modern Navy jet so I don’t know if this is the best way to do it. Look at pictures of modern F-14s and you’ll see what I mean by the intermittent grime all over the plane.
DJ
Hi dadfad[:)]
I have found there are plenty of different ways of weathering aircraft, so the method you choose will depend on what works best for you.
I’ve done a few F-14’s so I’ll tell you how I did mine.[;)] (low-vis scheme.)
I. Get the grey colours onto your model.(Light/dark Navy ghost gray I think it is.)
If you are painting a black cowl area around the cockpit,do that bit too.
2. Now the tricky bit[:0]! Study some pics of the paint scheme you want. (Home of M.A.T.S. is an excellent resource for F-14 data. I’ll give you the address later.)
You’ll notice the blotchy appearance of the aircraft, The best way I’ve found of copying this effect is to take the gray colour for the upper surfaces and use it to mix sublte darker(add a drop of very dark grey) and lighter (add a drop of white) shades. You can use the lighter shades on areas of the rear quarter and wings to show where new paint has been used to “touch up” those areas
and the darker shade can be used around panels (such as the boarding access panels, gun panels) where there is more wear and tear.When you finish blotching seal it in with a good gloss coat.
This can be quite time consuming but the result should be worth it[^]
For the panel lines and other surface details I use a wash of kiddies waterpaint. I paint one section at a time and leave to dry for approx. ten mins.
Then I take a damp peice of kitchen roll and wipe the excess away. This leaves a very nice “used look” to the painted surface.[;)]
The web address for Home of M.A.T.S. is: www.anft.net/f-14/
Sorry to ramble on a bit there, I hope this helps.[:I]
Good luck![:D]
Darren[;)]
Thankz Guyz, and ill show u my first modern navy ac soon!
I have about six of those Hasegawa F-14s in production right now. Hope to have at least one done before to long.
I’m also working on the “Wolf Pack” version, but I’m taking my time. I’m attempting to do the Pukin’ Dogs of VF-143 aboard Eisenhower. Great kits. I’m also using the 2 Verlinden detail kits, so I definately have my work cut out for me. (No pun intended)
demono69
