Wilbur,
There is a way I read many moons ago for representing the various shades of skin seen on an all-metal aircraft, and this information may be of use to you. It is based on Humbrol paint colours, but with experimentation, it could work with various other types of paint. Have to hand the following shades of Humbrol - A- either Silver(11) or Aluminium (56), B - Light Blue (65), C - Gunmetal (53), D - Brass (12), E - Medium Brown (62), F - White (40), G - Black (33), H - Medium Grey (HB6).
Because aircraft skin panels are of different thicknesses, the actual aluminium takes on a slightly different colour hue, even though they are all made from the same material. As a result, as you apply these shades and mixes, you can simulate the shade differences as you paint, rendering the weathering easier to do, since the colour variations are achieved through painting, rather than later ‘tinted’ weathering.
A + B (in the ratio of 3 parts A to 1 part B) Basic average light alloy colour for areas of average skin thickness.
A + B + C (ratio 2, 2, 1) Darker skin areas such as leading edges.
A + B + F (ratio 1, 1, 1) Lighter skin areas such as flying control surfaces and undercarriage doors.
A + B + D (ratio 1, 1, 1) Slightly stained areas such as undersides, panels aft of u/c doors, vents and openings.
C + D + G (ratio 1, 1, 1) Jet pipes, engine cylinders and insides of vents.
A + B + Graphite dust (ratio 1,1 for the paint) Polish the painted panel and then dust/brush on graphite dust. This technique can be used where you see slightly darker or shinier panels on the model.
Once these colours have been applied, you should then seal the finish before weathering.
It may seem complex, but have a go with an old model first - you will be surprised how, with some experimenting, you can achieve a very realistic finish! Try different combinations and ratios or even different colours! The effects are good fun and it means that after sealing, all you have to do is weather the whole thing without having to ‘tint’ your wash!
I hope this helps and leads to readers thinking laterally about finishes. Enjoy!
