Ok if i understand right this how to wash a air craft, 1. paint the model 2. Airbrush a gloss coat. 3. Use a 10% paint 90% thinner wash let set. 4. wipe it out with a Q-tip leaving it the crack. 5. let dry and put a flat coat over it? is this right there is so many was to wash which is best?
I like to clear coat the final paint with Future, then use oils or enamels for the wash.
Make sure you use a wash that won’t dissolve the paint it’s sitting on - never paint your final coat with enamels then do a wash straight onto this with enamels - you’ll just end up wiping the final coat off the surface.
Future seems to create a barrier that is impervious to oils or enamels. Otherwise you pretty much have the right idea.
Try looking in the painting forum - there’ll be heaps of posts about washes there. Maybe try the search function - that should be a help.
Cheers,
LeeTree
A Finescale article from November 2001has maybe the best weathering technique around:
http://www.finescale.com/fsm/pdf/quickeasyweathering.pdf
Check out this B-25 by Ian Holahan (NOT by me.)using the method:
http://www.accurate-miniatures.com/models/html/3431.htm
