Hello, Iam new to modeling and learning as i go with a lot of great info from this magazine and web site. Iam looking at weathering and would like to know if i can use Windsor and Newton oil based paints ?. or would i be better off using a paint that is specific to weathering. Thanks Rory.
[snWcm]Rory, you will find several different techniques for using washes on these forums. I use both, Windsor & Newton thinned with turpenoid, as well as enamel paints thinned with the specific brands thinner. I’m new to using washes myself; however, everything I have learned I got off these pages and from the helpful people on this site. My only word of advice that I’m sure you’ll get from others is to test your method on scraps before applying it to your actual kit. I’m sure you knew that already, but a reminder never hurts. Good luck and welcome to the group!
Hello Jelliott523, Thank you for the feed back on my question i will give it a try. What do you think of Revells Bf-109G-6 as this is a model i was thinking of purchasing as well as there new spitfire kit?. Once again Thanks for your advice and welcoming me to the group. Rory T
The G-6 is a pretty decent model. There are some complicated steps and the instruction book isnt the best written that I’ve seen. The recessed panel lines and other details are going to make this a nice kit in the end. The only issue I’ve had with the kit so far is the engine cowling covers. They do not fit the greatest and leave some larger gaps. I’ve had to use some filler putty, but its not a putty monster like some kits I’ve dealt with. If you want to look at some of the G-6 kits in progress from Revell, take a look in the Group Build section. I’m part of that build and have some progress pictures of mine in there, there are also a few others doing the same kit that have completed it.
Dont hesitate asking questions. Sometimes you might find that there are others with your same question.
W&N oil paints will work great. Just make sure u buy the professional grade
If you have a Hobby Lobby near you, print up a 40% coupon and save some cash. The ROG G-6 is very nice and believe that the ROG Spit is a re issue of the old mold.
The Revell spit Mk. 2 is brand new.
WnN oils are a really god choice, many seem to use them. Even though I have now moved onto AK interactive products for some of my weathering, the oil washes are still really useful.
So it must be the Revell 1/32 Mk.I then that’s a re issue. I saw it at a hobby store some months back.
Hello Rory and welcome. I can second the opinion for using thinned artist oils for washes. I also utilize Windsor and Newton artist’s oils. I have experimented with the cheaper versions in the past but have to admit that after the oils dried I could definitely see a difference in quality. The cheaper versions leave a not-so-consistent finish with many gaps and require reapplication. With the highest quality (albeit more expensive) oils one application and the wash flows perfectly into every crevice I need it to go. I thin the oils with a higher quality turpentine…bought in the same isle in the art store than I get the oil paint. A bit pricier (per unit) than the stuff in a larger can but again, quality is key to a superior finish.
I have been experimenting lately with Vallejo’s acrylic washes. I am not convinced they are a better substitute for thinned artist’s oils…but I am still experimenting. -Len
Will do thanks.
